2006 FLHPI key question
Old Aug 1, 2013 | 09:24 PM
katanaplanet's Avatar
katanaplanet
Default 2006 FLHPI key question
Do you leave the key in the ignition or can you take it out? I just got my bike and they lost the keys. But ts unlocked and when I turn the switch on the tank clockwise I hear the fuel pump noise but nothing happens when I press start button. Do you need key in all the time? BTW I ordered new keys but it takes 10 days.
In the mean time any trick to start without the key??
Old Aug 1, 2013 | 09:41 PM
bubdifab's Avatar
bubdifab
you dont need the key. is the bike in neutral when you are trying to start it? if not, you'll need to hold the clutch. safer just to have it in neutral though...
Old Aug 1, 2013 | 11:13 PM
katanaplanet
Of course!! I own a Victory kingpin and a sportser. I think there is some electrical problem. When I press run lever it turns on but nothing when I start. Where do I start?
Old Aug 1, 2013 | 11:15 PM
Road Star's Avatar
Road Star
Kill Switch?
Check fuses?
Old Aug 1, 2013 | 11:29 PM
katanaplanet
Kill switch- check
Fuses_ not yet
BTW how do you bypass ignition and start by connecting to starter solenoid? I see a thick red wire going in the starter.
Old Aug 2, 2013 | 09:26 AM
kirbyblue's Avatar
kirbyblue
If it has a security system and you dont have the remote. It wont start
Old Aug 2, 2013 | 01:41 PM
katanaplanet
how do I check if it has a security system? BTW I jumped wire from battery to solenoid and it started right up.
Old Aug 2, 2013 | 05:26 PM
kojak's Avatar
kojak
2006 FLHPI don't come with a security system unless someone did it later on. Your key doesn't have a fob on it for arming/disarming does it?
Old Aug 2, 2013 | 08:01 PM
hdbob2006's Avatar
hdbob2006
So you have a bad starter switch,or bad starter relay,or bad wiring in between switch,relay,or solenoid. Trace it down with a test light.
LUISROSALES
Apr 4, 2017 01:25 PM
frozensoul
Feb 25, 2016 12:48 PM
theabominablenick
General Topics/Tech Tips
Jun 11, 2014 10:40 AM
karlkcfi
Mar 8, 2011 11:40 PM
Dynamite17
Apr 4, 2009 04:37 PM
