Upgrading the TC88 -options?
Old Aug 14, 2013 | 12:42 AM
Road Star's Avatar
Road Star
Default Upgrading the TC88 -options?
I read a few posts about either rebuilding the 88, making it a 95, or getting a complete engine. The T111 costs $7K - I could sell my bike and get another bike for about $14k. Or, just look for another bike this winter for $7K.
Is that what a kit or new motor will cost? $7K??
Are there any other options? Maybe less expensive?
I see all these other bikers just pulling away from me, effortlessly. My 88CI is a slug. I was also hoping to convert it to a carb, primarily so it's cheaper and easier to tune.
Old Aug 14, 2013 | 01:09 AM
mkguitar's Avatar
mkguitar
a carb conversion need not be expensive- really good used Keihin CV carbs can be found for under $100 at swaps.
that would put some tunability in your hands- but you have to know what you are doing- otherwise do you gain?
the 95 is not expensive...pistons, cylinders and gaskets... the motor stays in place, parts and labor costs are low.
the TC88 was greatly hampered by head design- you could do headwork and cams and have a reliable, moderately powerful machine- there are a number of "packages" out there and you'd do well to research.
a builder will be interested in your budget, the model bike ( weight) gearing, type of riding and your expectations.
cost
power
reliability
you get to pick 2, the other is out of your control.
mike
Old Aug 14, 2013 | 01:15 AM
Road Star's Avatar
Road Star
cost
power
reliability
mike
Cost and reliability would be at the top of my list, however, I do want more power.
As far as my budget, I could spend $2k. What will that get me?
Old Aug 14, 2013 | 01:17 AM
Road Star's Avatar
Road Star
Also, is that S&S motor reliable? Easy to get parts?
Is it a twin cam design? Does it have the dreaded cam chain tensioners?
Old Aug 14, 2013 | 01:24 AM
mkguitar's Avatar
mkguitar
some good reading here:
http://www.nightrider.com/biketech/hdengines.htm
and more reading at the links on the right side of the page
mike
Old Aug 14, 2013 | 05:07 AM
grbrown's Avatar
grbrown
S&S engines are built as solid as the proverbial outhouse. The T series are twincams, but have S&S's own gear driven cams, so no tensioners! I have a V107 (predecessor of the 111) with just over 100HP/100TQ and a wide smooth effortless torque curve. A T111 should give you slightly better numbers. As for reliability, how long are you going to be riding?! S&S has been around 55 years and are probably the top aftermarket engine builder. You might gather I am a fan.....
Old Aug 14, 2013 | 05:39 AM
MNPGRider's Avatar
MNPGRider
For 2K you should be able to do the 95 kit with money left over. You could save even more by boring the jugs you already have, rather then buying new ones.
Check out Fuel Moto's conversions as well. For $2595 you get 98", everything installed, including a dyno tune.
http://www.fuelmotousa.com/site/98-inch-big-bore.html
Old Aug 14, 2013 | 06:26 AM
Weavr99FLHT's Avatar
Weavr99FLHT
My TC88 would leave stock TC96's in the rearview mirror. My TC88 had stock displacement, stock heads, large SE Mikuni Carb, SE 203 Cams, SE air cleaner and the older (race only) SE II Performance Slip-ons (the good ones). The first time I got on my TC96 (2008) I went back to the dealer and asked for the rest of it and my Svc Mgr laughed and said "that's most people's response".
Old Aug 14, 2013 | 06:28 AM
simpkinst's Avatar
simpkinst
What year 88? It makes some difference in options. Do you have anything done to it now or is it stock?
I have PCIII, k&n filter, v&h exhaust, and Andrews cam in mine and it really woke up the 88. Ride with a friend that has a 103 and have no problems "keeping up".
Also not sure about spending money switching to carb. Once tuned, your not going to mess with either.....
Anyway for under 2k, you can get more power out if the 88
Old Aug 14, 2013 | 06:42 AM
JustDennis's Avatar
JustDennis
Yes there are less options to tune on a carb and you just need jets, needles and a little know how but you could get a good tuner for what it would cost to switch over to a carb and have more options and get a great tune. You could have it tuned or tune it yourself with many of them.
