New Monkey Bars...ABS question
Old Aug 22, 2013 | 04:37 PM
Skippy97's Avatar
Skippy97
Default New Monkey Bars...ABS question
Hey All,
Going to install 12" PYO Monkey Bars. After I refill/ bleed brakes after install, manual says to use ABS machine at dealership to ensure ABS system working and no air in line.
Question: will the brakes still work without machine? Would like to drive it to dealership to get service to ABS...would hate to have to tow if brakes still work.
Thanks!
Old Aug 22, 2013 | 04:40 PM
denalion22's Avatar
denalion22
drive it over and have them reset... i did and it was fine
Old Aug 22, 2013 | 04:43 PM
SBates08's Avatar
SBates08
Yes they will still work just not the ABS. If your careful not to introduce air into the system and bleed your brakes properly you may not have to go to the dealer at all. You'll know as soon as you take off on it if the ABS is functioning as it should. The ABS light will go out like before. If the ABS light stays on then there's a good likelihood that air has gotten trapped in the ABS unit.
Old Aug 22, 2013 | 06:44 PM
glider69's Avatar
glider69
Just use a hand vacuum bleeder. If you don't have one you can go your local auto parts and buy an inexpensive one for 20-40 dollars bleed it out and away you go. I've did many sets of apes on abs bikes and it worked just fine. My bike has over 10k since the bars were put on with no problems.
Old Aug 22, 2013 | 07:37 PM
elky72ss454's Avatar
elky72ss454
That's what I did and mine work fine.
johnxllis
Aug 14, 2017 06:55 PM
squaredaway
Aug 31, 2013 08:51 AM
Sonic69
Jul 4, 2011 09:49 AM
Chewwi
Jun 4, 2010 09:58 PM
DeputyMike
Feb 10, 2010 07:17 PM
