Experience with Dyna-beads?
Old Aug 24, 2013 | 09:22 PM
roadrunner10's Avatar
roadrunner10
Default Experience with Dyna-beads?
I would like to believe everything I read about Dyna-beads but I'm skeptical. Has anybody that has actually tried them, swear by them ? Do they work? Better than dynamic wheel balancing? Waste of time? Would it help on tires that are half way through their tread life?
The vibration I'm feeling isn't really bad, but it is there, at highway speeds and it bugs me.
Old Aug 24, 2013 | 09:33 PM
rob0225's Avatar
rob0225
I am using them for the first time. Got about 2k miles on them so far. I have no issues.
Old Aug 24, 2013 | 09:35 PM
Inspector 12's Avatar
Inspector 12
I've got them in both of my bikes. Love the fact that I don't have tape weights on my mag wheels and still have a great balance.
Old Aug 24, 2013 | 10:05 PM
roadrunner10
Is a "great" balance a perfect balance? Smooth as glass? Just like the ad says? Or, are you settling for even a little vibration but that's better than taping weights on your mags?
I don't mean to sound harsh but I'm looking for the best balance with NO vibration. I'm close now,(with stick on weights) but not PERFECT.
Old Aug 24, 2013 | 10:51 PM
skydude426's Avatar
skydude426
Have them in my front tire. It rides smooth. No vibration. So far they seem to work good.
Old Aug 24, 2013 | 11:04 PM
'05Train's Avatar
'05Train
Snake oil. The beads simply cannot do what they claim to do.
Old Aug 24, 2013 | 11:05 PM
Juan L's Avatar
Juan L
Moderator
I JUST put 1 oz. of beads in my new front tire with tube. After changing tires, the indy said no weights were required on the front but having never seen a tire with a tube that was perfectly balanced I was skeptical. Sure enough my suspicions were confirmed on my first ride as I have a "buzz" in my handle bars at about 70 mph. I bought some Dyna beads from DK Customs, one of our forum sponsors, and put them in tonight. It was easy as pie because all I had to do was tap on the plastic tube and they went right into to valve stem with the core removed of course.
Took a slow speed ride this evening up to about 40-45 and no issues, no hopping tires, no out of balance condition that I could detect. Monday on my ride to work I'll get it up to speed and see what it feels like at highway speed. If the "buzz" is gone I'll pop the weight off the rear tire and put the beads in the rear.
I have read your numerous posts on this subject on other threads and can say that you obviously don't understand the physics. Don't go on about how they "can't" work because according to many people they do. Tires are not segmented like a roulette wheel on the inside and the beads can move. I will know for sure on Monday.
Inspector 12
I am not one to compromise and accept "close enough" for asthetics. The problem with any permanent weight installation is that as the tires wear the balance point generally moves. One of the reasons that most tire store rotate and rebalance tires on automobiles every 5000 miles. With Dyna Beads, they constantly go to the right spot in the tire to balance them. Bead type balancing has been around the trucking industry for a long time but seems to be fairly new to the motorcycle community (last 3 to 5 years).
Old Aug 24, 2013 | 11:08 PM
p51bombay's Avatar
p51bombay
I'll never use anything else, very smooth an nice even tire wear.
Old Aug 25, 2013 | 12:46 AM
rpking's Avatar
rpking
I cant say anything about tire wear cause I only have about 150 miles on my new 21" tire since I put it on
But as far as vibration, so far so good, I don't have any, my bike rides as well with the dyna beads as it did with ugly weights
