High and low idle?
Old Sep 14, 2013 | 03:42 PM
scglide's Avatar
scglide
Default High and low idle?
2011 electraglide, 20,000 miles, I started my bike this morning and idle jump to about 2000 rpm on the way home from work got off freeway and I had to keep reving it so it wouldn't die, anyone else have this problem or know what it might be.
Thanks,
Steve
Old Sep 14, 2013 | 06:25 PM
scglide's Avatar
scglide
Anyone? Bueller?
Old Sep 14, 2013 | 06:49 PM
mkguitar's Avatar
mkguitar
any tuner onboard?
I have had some high idle concerns, in the past anyway- to reset the throttle position sensor;
with RIGHT HAND, turn on ign. switch.
let pump prime, then switch off.
repeat 4 more times.
that resets the TPS.
it is possible that if you are using the kill switch that your hand is resting on the throttle as you switch the motor off.
I am now in the habit of using the ign switch with right hand to avoid spurious inputs.
pt 2.) this could also be corrosion of the contacts on the servo motor plug on teh throttle body ( 7 oclock as you look at the intake).
pull the plug, clean the contacts and reinsert.
some use dielectric grease to keep moisture out.
I do not as it can also trap moisture in...
or if you have a tuner, look there
mike
Old Sep 14, 2013 | 07:11 PM
scottma978's Avatar
scottma978
hey does anybody know if that tps reset works on my "07 (has throttle cable, not throttle by wire)?? I have noticed a few times lately that my idle wouldn't drop down to idle for over an hour, then it will get into a cycle of wanting to stall at a stop light if I do not feather the throttle. I put a little sea foam in the tank just for grins,....but that was before the idle wouldn't drop..it seems to be intermittent. thanks in advance if anyone has any ideas.
Old Sep 14, 2013 | 07:44 PM
TWIN CAM 96's Avatar
TWIN CAM 96
I believe your problem is going to be a dirty IAC. Mine does the same thing I just buy a can of CRC mass flow sensor spray cleaner with a 45 or a 90 deg. straw & with your ign. switch on flip your on - off switch 4-5 times while spraying your IAC be sure to use a clean lint free towel in the throttle body to catch the dirt. This a annual or bi annual thing to clean for me or you can just buy a new one every time about $ 65.00. Good luck!
Old Sep 14, 2013 | 09:51 PM
scglide's Avatar
scglide
Thanks for the responses, no tuner and i never use the kill button, I will give all the suggestions a try, hope it works.
Thanks again,
Steve
Old Sep 14, 2013 | 10:46 PM
SOCALHD's Avatar
SOCALHD
Likely your Throttle by Wire inside the hndle bars. but warranty will rplace
Old Sep 15, 2013 | 03:46 PM
Dustball's Avatar
Dustball
Ding...ding...ding. Winner!
nicmartim
Jul 7, 2018 05:47 AM
Afdharley
Screamin Eagle CVO Models
Apr 3, 2015 09:25 AM
Moochoff
Jul 11, 2014 05:12 PM
gww303
Jul 5, 2014 01:15 PM
12hdrk
Apr 13, 2013 08:57 AM
