Thundermax help
Old Mar 7, 2007 | 08:24 PM
cowboyglide's Avatar
cowboyglide
Default Thundermax help
Ihave an07 SG with Rinehart true duals and the newSE proheavy breather with the K&N filter. I installed the Thundermax with integrated autotune.
First let me say I had no idea the 96 was capable of the performance you get with the thudermax. The
bike just screems. No heat issues or aything negative except I have decell poping from 2300rpm down toidle in 3rd, 2nd and 1st. From eveythingI've read from others who have and love the thundermax I am one of the few with decel poping problems. I've been workingwith the guys at Zippers and so far they areas baffeled as I am as to what the problem is.I won't bore you with all of the fixes we've tried. I would like to hear fromanyone that has the thundermax with auto tune and the same or similar set up as mine whether you've had the same problem or not. Thanks for any help in advance.
Old Mar 7, 2007 | 08:34 PM
bountyhunter's Avatar
bountyhunter
Default RE: Thundermax help
You mean you just can't drive it around the block a couple a times and expect a precise tune?[sm=wtf.gif]
Old Mar 7, 2007 | 08:45 PM
cowboyglide
Did I give you the impression from my post that I thought I could just drive it around the block a couple of times and get a precise tune. I hope there others on this forum that can be helpful.
Old Mar 7, 2007 | 08:57 PM
bountyhunter
[sm=icon_rtfm.gif] COWBOY![sm=feedback.gif]
Old Mar 7, 2007 | 09:04 PM
Johnny Law's Avatar
Johnny Law
cowboyglide,
Shot in the dark here. I had decell popping on my RKC when my crossover pipe cracked causing an exhaust leak. I welded it up and had no more decell poping. I realize you have the true duals. Is it one or both pipes popping ? Other thing I have heard of is a lean condition on decell that can cause that. Im sure there are a bunch more things thats my .02 cents. Keep us updated on the fix. I am planning to order the same setup in a few months for my UC.
JL
Old Mar 7, 2007 | 09:11 PM
ULTRA Gramps's Avatar
ULTRA Gramps
I was wanting to order the thundermax, I am very interested if this can be fixed?
Old Mar 7, 2007 | 09:14 PM
cowboyglide
I thought about an exhaust leak so I removed the pipes and put in new gaskets even though they were only a couple months old and I resealed the muffler to tail pipe with the recommended copper high temp silicone. Didn't help. I added more fuel to the closed throttle positions from 2600 rpm down. Didn't help.
Thanks for your input.
Old Mar 7, 2007 | 10:58 PM
shooter64's Avatar
shooter64
Former Sponsor
Just a couple of things to check.....is the new air cleaner seated well, no intake leaks anywhere, would be interested in seeing your map, and just for grins, try another map, something close but different, and ride it about 100 miles and with at least three stops and starts, and see if it goes away.
Old Mar 8, 2007 | 01:05 AM
BikerGent's Avatar
BikerGent
Yo Cowboy , I have V & H slip on's a Wimmer air intake and the T Max auto tune I also have the same thing U have popping and backfire on DE cel I talked to zippers and they gave me 2 maps to use 350 for stock pipes and 352 for the pipes krome works ,he said was close to V & H , have not tried it yet but when I do I will let you know outcome have they given you any new maps to try ??
Old Mar 8, 2007 | 01:12 AM
Arizona's Avatar
Arizona
I'm seriously thinking of going with the Tmax system, I've heard great reports on it. Any others who have it that can give input?
Thanks!
