2014 Limited - Clunk from fairing area when hitting small bumps
Old Oct 1, 2015 | 01:53 AM
iwillfixthem4u's Avatar
iwillfixthem4u
I also started hearing noise on big sharp bumps ( like top out springs). I have the bike apart to install chrome front end. I notisted that one of the fork tubes binders in the slider. Will post the sulotion when I have it. For you that have taken the forks apart, once the lower bolt is removed and the sling clip above the seal is removed ,you pull the elder from the tube and it drives out the bushing and seal, mine gets stuck as I pull the slider from the tube. Thinking fork leg is distorted causing noise
Old Oct 2, 2024 | 06:31 PM
pccolella's Avatar
pccolella
Stage I
Did you ever resolve this? My 2014 Ultra does the same thing, Been living with it since I've owned it, 6 years, but it has gotten worse. Bike is at HD now and they can't figure out what it is.
mickeylynn
2014-2024 Touring Models
30
Apr 17, 2016 10:10 AM
Benito
May 29, 2014 04:44 AM
run1fsr
Mar 23, 2009 09:38 PM
catcher
Oct 12, 2008 03:20 PM
sortasuave
Feb 28, 2007 05:10 PM
