Cam install question
Old Sep 30, 2013 | 04:48 PM
HDV-GLIDE's Avatar
HDV-GLIDE
"Secondly, There is no need to replace the inner cam bearings on newer TC motors (96 ci and up)."
If you compare the difference between the stock bearings and the SE/Torrington Bearings, you would have a different outlook. To each his own though.....
Old Sep 30, 2013 | 05:21 PM
12hdrk's Avatar
12hdrk
No doubt, but it's just me that while I'm in there why not spend 15.00 on the bearings? The tool I can sell or rent or loan.
Old Sep 30, 2013 | 05:24 PM
12hdrk's Avatar
12hdrk
Originally Posted by fat daddy
I'm with you on this I won't even tap in a wheel bearing let alone cam bearings. If the op lived near me I'd let him borrow all the tools he needs. I think he will do just fine if he leaves the hammers in the box imho
Yea. After spending over 25k on my bike so far, the hundred for the proper tool seems insignificant. Obviously I'm lucky to be in a position to say that.
Old Oct 1, 2013 | 08:32 PM
12hdrk's Avatar
12hdrk
Update on the Heartland cam bearing tool:
Great tool. Easily self centers for removal and install. All you need to do is turn the wrench. Takes 5 minutes to remove each and same to install. Sets bearings almost exactly per spec. About .007 deeper than spec, but the slight angle my caliper was at could have accounted for that variation.
Old Oct 1, 2013 | 08:53 PM
fullautomike's Avatar
fullautomike
I agree 100% The right tool for the job at hand!
If I installed bearings often, then I'd know what to expect and have the "touch", and might be comfortable tapping them in. There is no way I'm going to "warm up" on my bike! Besides I've got a tool fetish, If there is a specialty tool for a job I'm doing that is worth using , I'll buy it, or make it.
Why would you not replace the bearings? $15?? Lunch costs more!
How far have you gotten?
Old Oct 1, 2013 | 09:00 PM
12hdrk's Avatar
12hdrk
Originally Posted by fullautomike
Sounds good. I've never done them either, but I'm in Oxford, so if you want a helper, or a second hand I'd be willing to stop over. Anyway, thanks
So those Hartland tools look good? I was wondering about them. I also want to press the bearings in, not tap them.
Thanks for the offer, but I'm going to finish up tomorrow. I took the rest of the week off. Had a little surprise I posted in another thread. Found some metal shavings in an oil passage. Check it out "unwelcome surprise..."
Tools are just fine. I'll hold them for you if you like... We can work something out. I'll PM you when I'm done.
Old Oct 1, 2013 | 09:08 PM
fullautomike
I hate surprises!!! I'll check out the thread...Good luck!!!!
Sure, shoot me a PM when you are done, thanks, no rush.
Old Oct 1, 2013 | 10:46 PM
okcjetmech's Avatar
okcjetmech
Wow!!! I feel cheap. When I repalced my inner cam bearings on my 05 softail, I only paid about $7 for both torrington bearings......
And I agree, buy the tools. Ive helped quite a few people do their cam swaps it makes it so much easier..
Old Oct 2, 2013 | 07:38 AM
Eshaw301's Avatar
Eshaw301
If your bike only had 251 miles on it when you changed cams than I guess I could see why you didn't change bearings but if one has many more miles on his engine he might be further ahead to change them out,it's really not that hard to do.
I guess you skipped over the part where I said I just inspected my bearings after 10k miles and they were perfectly fine. No chips, wear grooves or anything like that.
Derek Morrison
Engine Mechanical Topics
Dec 6, 2017 10:44 AM
barcoeng
Mar 15, 2016 10:06 PM
LeFat1
Exhaust System Topics
26
Apr 28, 2013 01:21 PM
cromagnon
Feb 22, 2011 06:49 AM
jackinthebox
Oct 12, 2010 05:56 AM
