Bagger wobble solved!
Old May 4, 2014 | 12:23 PM
  #101
woodman's Avatar
woodman
So GoofSB did you finish and test ride yet? I did the swingarm rebuild on my 06 a few months ago with the front motor mount replacement also. The bike tracks great but I had a whole lotta shakin going on. Frustrating. It felt like the motor mount was bad in the front again. I ordered and installed the Glide-Pro motor mount and the vibration is gone from my handlebars. What a huge difference. Just my take on this. I have no affiliation with Glide-Pro. Just a happy rider now. The 90718-79C mount was the cause of my vibration. Problem solved .
Old May 4, 2014 | 12:33 PM
  #102
woodman's Avatar
woodman
Sorry wrong number on the motor mount 16207-79D is the Harley mount I replaced with the Glide-Pro mount. 90718-79C is the number for the Support saddle bracket that I replaced when bushings and Aurora Bearings installed in swingarm
Old May 4, 2014 | 11:13 PM
  #103
brizyo's Avatar
brizyo
2nd Gear
Angry wobble
07 Road King with 11,000 mi. Just started a wicked high speed wobble.
ck tire pressure, set to 35 lbs thought it was gone then today passing a car doing about 70 and OMG !!! Read about swingarm bearings could this be the problem on a bike with so few miles? Never had this problem on any of my big Jap bikes.Will ck out swingarm and see
Old May 5, 2014 | 09:49 AM
  #104
woodman's Avatar
woodman
You might want to set rear tire at 38-40. That is Harley recommendation for tubeless not sure if the same on tubed tires.Check your front motormount also.Bolt through it should be torqued 15-20 FT LBS.
Old May 5, 2014 | 10:08 AM
  #105
grbrown's Avatar
grbrown
Welcome to HDF from the UK. It sounds as if your tyre pressures are way off. Read this thread through and attend to the things mentioned that can affect your bike's ride quality, before you start fitting new parts.
Old May 7, 2014 | 09:20 AM
  #106
woodman's Avatar
woodman
Definitely!
Old May 7, 2014 | 10:59 AM
  #107
GoofySB's Avatar
GoofySB
Woodman, It's done. So far I've only put about 35 miles on it and since the rear tire is new, I didn't push it too hard. However, it does seem better. Seemed like the rear was tracking the front better and like they were more glued together, but that's a first impression at 60 or 65 mph. I didn't notice any change in vibration anywhere. Once the tire is more broken in and I hit some curves at speeds with previous issues, I'll report back.
Old May 20, 2014 | 02:56 PM
  #108
Dun Roamin's Avatar
Dun Roamin
Going back to the Aurora bearing ... why spherical instead of plain? Is there some hidden advantage?
I see STA-BO do 'ED16' bearing replacements
Has anyone machined up a STA-BO I to suit the later larger diameter spindle? Or STA-BO I equivalent.
Thanks
Old May 20, 2014 | 03:31 PM
  #109
dyna07custom's Avatar
dyna07custom
http://www.ebay.com/itm/AURORA-GE25E...-/291050042447 here they are on ebay for 24.00
Old May 22, 2014 | 02:51 AM
  #110
madmanbob's Avatar
madmanbob
2nd Gear
great post Thanks for the info.
