My 2014 CVO Limited issues thread
Old Oct 9, 2013 | 04:26 PM
  #51
roadglider05's Avatar
roadglider05
Good Luck on the repair, I am glad I have a good one so far,3600 miles and runs strong. Harley got it right but issues may follow, I may trade for the new Road Glide in 2015 but not without 15,000 miles on the 2014, Yes still working full time and only 7 months of riding in northern NY. Safe Riding and Good Luck
Old Oct 9, 2013 | 07:26 PM
  #52
Boltsfaninmo's Avatar
Boltsfaninmo
Originally Posted by Boltsfaninmo
Day 6:
Dealer just called and said my bike is fixed. He said all of my radio issues will be addressed in future firmware updates. He did say MoCo is aware of them. He mentioned too a problem with iphone 5 and the 7.0 update which I have. Anyway, I'm really not worried about the Radio glitches per se. I am worried about the coolant exploading/leaking/puking, etc.
To "fix" my bike's coolant puke problem. All they did was the same thing they did last Friday night on Day 1. They waited for the bike to fully cool. Opened the radiator cap. Ran the bike for 5 minutes with the cap off. Addded the correct amount of coolant took it for a "long" (not sure how long) test ride. Turned off bike let cool down. Did that whole process again and they say no issues.
I asked if they performed the technical bulletin TT430 or whatever it is, and he said no, that they didn't have to do any of that. He said they may have to in the future, but didn't need to now.
I'll pick her up tonight, take her for a ride, and report back later, but I'm not so sure what they did fixed anything. I also wonder why it took them all day Monday, Tueasday, and half the day today to do such a small proceedure? Anyway, I fear the saga continues....
Day 6 continued...
I picked up my bike, but first I must clarify something. The tech I spoke with when I arrived at the dealer was not only a different guy than I had spoken to earlier, but also he was telling me something completely different than the prior guy told me.
He said the problem was the system just needed to be purged. He said they misunderstood what MoCo told them to do when they told the dealer to run the bike for 5 minutes with the cap off. What MoCo meant was to run the cooling fans and pump for 5 minutes. So, they did do that twice, and test rode the bike I'm thinking around 15 miles or so. I rode it home another 16 miles or so, turned off the bike via the kill switch and the fans immediately turned on for about 8 seconds. The coolant level didn't budge and no leaks.
For those of you who want to run your fans simply shut off the bike if it's on, turn on the kill switch and turn the throttle half way or more until the fans turn on and let go. The fans and pump will continue to run for how long I don't know. To stop the fans just hit the kill switch again.
I'll definitely be keeping an eye on things and update you all if anything changes.
Old Oct 9, 2013 | 07:51 PM
  #53
Rootro's Avatar
Rootro
Just turn off the kill switch, do a back flip, click your heels 3 times and do a forward flip and balance on your nose on top of the coolant cap while you rotate the throttle half way, problem solved. Does any of this seem normal, why should you have to do this on a bike that costs this much. Really?
Old Oct 9, 2013 | 08:06 PM
  #54
Geoff's Avatar
Geoff
I'm thinking of adding a new bike to my stable, a '79 Low Rider. The bike has only 3200 miles and doesn't leak fluid.
Old Oct 9, 2013 | 08:12 PM
  #55
Boltsfaninmo
Originally Posted by Rootro
Just turn off the kill switch, do a back flip, click your heels 3 times and do a forward flip and balance on your nose on top to the coolant cap while you rotate the throttle half way, problem solved. Does any of this seem normal, why should you have to do this on a bike that costs this much. Really?
Well, regardless of the cost. I agree. Seems strange that my bike ran almost 1400 miles just fine before it puked. I'm not mechanic or brain surgeon, but really? Wouldn't a system that apparently needed to be burped, puke a lot sooner than 1380 miles? I told the tech I'm fairly confident I'll be back.
He did give me a whole lot of insight into what they (dealer) has to go through with MoCo to get questions answered on how to service the bikes. After speaking to him I see MoCo has a much bigger problem than I thought. He did say MoCo has taken their best techs and put them on segregated teams. In other words, you have a team of people who work strictly on the Infotainment issues. You have a separate team who will work on Twin Cooled bikes, etc. It's created quite the back log of issues. A tech may call MoCo to get help with 3 bikes needing attention. He'll wait 40 minutes to speak to the tech from the correct team. He'll ask questions for say the two twin cooled bikes, but then cannot ask his question about the 3rd bike because say it's a Breakout? Well, the twin cooled guys cannot speak to him about the Breakout, so he has to call back, wait 40 minutes to speak to the tech working the Breakout platform. Completely ridiculous if you hear the whole story. Anyway, for now my bike is working.
Old Oct 9, 2013 | 08:18 PM
  #56
Boltsfaninmo
Ah....Okay?
Old Oct 9, 2013 | 09:54 PM
  #57
PA1195's Avatar
PA1195
I do hope it's fixed for you forever. You'll be able to see within a couple thousand miles if the purge lasts and the components keep functioning. I hope for all there's no sealing issue that would allow one-way air ingress via a seal or whatever over time. Not suggesting there is however.
If I were HD I'd suction as well as pressure test the radiator cap fitting. Assuming the cap allows easy flow of reservoir coolant upon engine cooling, it shouldn't be a problem. If the system can ingest a little air somewhere easier than the reservoir coolant, it may be an unknown issue.
Please keep us informed.
Old Oct 9, 2013 | 10:27 PM
  #58
Teardrop's Avatar
Teardrop
My exact thoughts except you forgot the part where you have to remember to turn the bike off after 10 minutes or the water pump will drain the battery dead. I think the MoCo has done a half *** job of designing this system and they should have done more R&D before they released it to the public. I feel for any of you guys that have issues and I hope they get it right.
Old Oct 9, 2013 | 10:42 PM
  #59
cfreeze's Avatar
cfreeze
every shovel i owned leaked fluids, it just wasn't coolant.LOL
Old Oct 10, 2013 | 12:33 AM
  #60
bingram1's Avatar
bingram1
You beat me to it....... Or was it called marking its territory.
