Replace SE Compensator - Dissater!
Old Oct 17, 2013 | 09:50 PM
jackhis's Avatar
jackhis
Originally Posted by av ultra
Ya know, at 10k I replaced my 2010 stock with a se unit because of all the threads on failed stock compensators, first of all my stock was in perfect shape, but since I had the se unit already I stuck it in. I have about 3k on the se unit and really cannot tell any difference, good or bad. This dec. I will probably take the primary cover off & check it all out, I've seen the se comps wrecked. On your problem I would take it apart asap, it shouldn't make any more noise then stock, something's wrong.
Thanks. That's the plan.
I'm just kind of upset to myself after a couple hours of sitting, crawling on the floor inside a hot garage (~85F), and the result is suck!
I bet I can ride another 40K miles with the stock comp., but it is not the point now.
Gotta do it all over again.
Old Oct 17, 2013 | 09:53 PM
jackhis's Avatar
jackhis
Originally Posted by r0de_runr
You may not have put the disks in in the correct order, that would probably make a lot of noise as the disks are the springs.
It should be correct, but I will check everything again.
Thanks much for the thought.
Old Oct 17, 2013 | 10:06 PM
hog95023's Avatar
hog95023
Hope you don't find this
My comp held though, I'm still replacing it lol
Old Oct 17, 2013 | 10:09 PM
jackhis's Avatar
jackhis
Damm! It appears the tensioner melt down!
I'll rather take that than anything else.
Old Oct 17, 2013 | 10:17 PM
hog95023's Avatar
hog95023
The lower half of the stock clutch basket
Old Oct 17, 2013 | 10:24 PM
jackhis's Avatar
jackhis
How's that happened? A lose bolt or a foreign object that's not suppose to be in there.
I hope I don't see that "crime scene" next week, when I reopen my bike.
I wonder whether there is any damage to the primary cover and its frame.
Old Oct 17, 2013 | 10:36 PM
hog95023's Avatar
hog95023
Chrome harley inner primary. I have a 124 motor, on the highway when happened. I doubt yours broke, but all I heard was a pop and felt a little flutter. Shifted a little different but not as bad as one would think by the looks of it. Stock clutch basket will now be upgrading to an evo industries complete clutch
Old Oct 17, 2013 | 11:31 PM
jackhis's Avatar
jackhis
Holy crap!
I guess oil was all over through the crack.
Somehow, I have a thought of what I have done wrong, but I need to open the cover see the damage, if any, and to confirm and clarify my stupidity.
Thanks for sharing your experience.
Nick
Old Oct 18, 2013 | 02:47 PM
jackhis's Avatar
jackhis
Found the problem and fix it!
No more rattle noise.
Thanks everyone.
Old Oct 18, 2013 | 02:56 PM
r0de_runr's Avatar
r0de_runr
dont leave us hanging...
what was it?
