87 flh police blinker issue
Old Oct 19, 2013 | 11:59 AM
defarmer's Avatar
defarmer
6th Gear
Default 87 flh police blinker issue
I have a 87 flh police model and the blinkers only work when i hold down the signal button. once its released they stop. they flash fine its just a pain trying to hold the button and drive. where should I start. Thanks in advance for any info.
Old Oct 19, 2013 | 12:11 PM
mkguitar's Avatar
mkguitar
AFAIK the '87 does not have self canceling turn signals, so instead of the current style "momentary" push button for the blinkers, you should have switches which stay depressed until cancelled by the rider.
( I have an '88 CHP, FXRP)
the flasher is the old car type thermal break- easily replaced with a plug in electronic type- that'll solve any problems with owner changed bulbs too. ( autozone $15)- such as LEDS or low watt, deleted signals or even high watt bulbs
the system is very simple...
hot from the fuse box to the flasher module- then from there it splits to the 2 switches ( L.R) then to the lights ( L or R)...and through the bulbs to ground
if original switches, they may just be crudded up internally
mike
Old Oct 19, 2013 | 02:22 PM
tehan2's Avatar
tehan2
did you check the blinker fluid?
ok seriously, did they work before? some aftermarket lights require a load equalizer.
something like this
Old Oct 19, 2013 | 08:48 PM
defarmer's Avatar
defarmer
6th Gear
ha ha blinker fluid is fine so are the muffler bearings. but really the blinkers flash fine it must be the switches you have to to hold them down for them to work. Thats where i will start.
Old Oct 20, 2013 | 07:41 AM
bagga's Avatar
bagga
i have to hold the button on my 85 too. it's just the way they are.
Old Oct 20, 2013 | 07:58 AM
VTL nut's Avatar
VTL nut
Mike gave some very accurate advise. If it doesn't work as he prescribed, they could given his instructions.
Old Oct 21, 2013 | 04:21 PM
defarmer's Avatar
defarmer
6th Gear
Thanks guys. Its just the way there are. This is the first pre 2000 harley i have had so i didnt know any better and have been spoiled by self cancelling blinker modules
Old Oct 22, 2013 | 08:41 AM
grbrown's Avatar
grbrown
Wink
But they don't have to stay that way! My 1990 Glide has flashers (self-cancelling etc) with one press operation, but that didn't become standard across the board until a while later. IIRC Badlands make a flasher module which may fit your bike, so take a look at their website.
Old Oct 23, 2013 | 10:26 AM
defarmer's Avatar
defarmer
6th Gear
Thanks grbrown I will check that out
met
Jul 17, 2018 11:20 AM
mitchflhx
Shovelhead
Aug 28, 2017 08:35 PM
trentminer
Mar 13, 2012 09:51 PM
sgtjeff
Oct 7, 2008 12:28 PM
klubbo
Shovelhead
17
Jan 10, 2008 09:04 AM
