07 Road King battery draining
Old Oct 31, 2013 | 07:45 AM
Tnywill's Avatar
Tnywill
2nd Gear
Default 07 Road King battery draining
I have an 07 Road King and something seems to be draining the battery. I had the battery checked and it's good. I hard charged it overnight and the battery will last about 2 days and then it doesn't have enough juice to start it again. Any ideas?
Old Oct 31, 2013 | 07:48 AM
rleggs's Avatar
rleggs
Sounds like you need to check your charging circuit. If you have a service manual and a meter it's not a hard job.
Old Oct 31, 2013 | 09:29 AM
lionsm13's Avatar
lionsm13
Is it the original battery, you didn't say?
If so, I'd change it out.
If not then could be several things, stator, voltage regulator, etc.
Old Oct 31, 2013 | 10:40 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
+1.... you beat me to it.
Old Oct 31, 2013 | 12:04 PM
knlcox's Avatar
knlcox
I recently battled a similar issue... I would have to jump start it if it sat for more than 6-8 hours. I ended up pulling the battery out and then cleaned, scrubbed, & scraped all of the leads, washers, & terminals. Nothing appeared to be corroded at a glance but after I got nice new metal on metal contact I haven't had a bit of trouble. I haven't even put it on the tender while having it sit for a few days.
Old Oct 31, 2013 | 01:28 PM
mkguitar's Avatar
mkguitar
batteries "drain" if there is a wiring fault, a bad diode in the voltage regulator or even dirt on the battery...current can flow through the dirt from pole to pole.
or the battery could just be done and unable to hold a charge
once fully discharged- as it seems this battery has been- the capacity to hold a charge is reduced by about 40%.
each of these possibilities can be checked with a meter and some smarts.
be warned that a bad battery- if yours is- can destroy the charging system.
a $100 fix becomes a $500 fix
check this thread for fun and hilarity:
https://www.hdforums.com/forum/touri...cable-pic.html
mike
Mountain Cruiser
2014-2024 Touring Models
15
Nov 7, 2017 03:32 PM
Aussie_61
Jul 5, 2015 08:46 PM
Bigwillie
Jan 11, 2012 05:20 PM
HDRider2002
Jul 22, 2009 08:19 AM
Sledriver
Apr 1, 2007 08:40 PM
