which brand and why??
is one better than the other or is it personal preference??
as of right now i'm running stock header pipes with V/H slip on big shots,stage1 air filterand the race tuner..
the bike runs great and sounds awsome..but i hate the look of the slip on's...they are 4" slash cuts which look fine it's just the megaphone style of the muffler itself i dont like..
Iwould like to switch to tru duals soon , just not sure which ones...
thanks..
ps it's a 06 rkc..
Don't get sucked in with what all of the websites say about duals adding 7hp and some torque.On astock Harleythey simply don't. But they do sound good
. True duals will help get rid of some heat you feel at your right leg, but on a stock bike IMHO it's not worth giving up the torque loss where you need it the most. If you can live without it and never have a passenger then it's a personal thing/choice.
Now if your building a bike like BraynTTM and some others here that have some serious torque...and horsepower...those babies need to breath.
I repeat, youâre going to get a lot of different opinions here that disagree. Go talk to a dyno tuner, they won't charge you to justtalk to them. Let them help you make up your mind.
I founda guy that sells them for $460, but that's just for the slip on's not head pipes.
www.pipecity.com
With that said get which ever one appeals to you most. I like the sound of the Rineharts myself but very much would like to try Vance & Hines, I'm not sure this is a bad choice.
p.s.....I ran them on a stock motor for awhile before I did all the motor work.
Like a lot of parts its what you like best, since you say you have a good sounding, good running, setup and just want to change because of the looks. Its obvious you are motivated by looks over function, so just pick the one that meets your "look" needs best.
True duals mainly for looks and sound and mild builds.
V&H,bubs,and bassani duals sound good, i havent rode behind any other td's on the highway.
He suggest if the engine is (stock/near stock) leave the cross over pipe and just add the slipon's.. since they did the race tuner in the first place the will re-tune for free...
will keep you posted on the outcome..
thx, paul
