Riders back rest ????
Old Mar 13, 2007 | 08:42 PM
Warbux's Avatar
Warbux
6th Gear
Default Riders back rest ????
I got a back rest off E-bay, installediton my 03 ultra ,rodewith itforthe first time today Iam setting almost onthe tank with the bracket set as far back aspossiable any ideas ???????? thanx Joel
Old Mar 13, 2007 | 08:46 PM
jeepster09's Avatar
jeepster09
Default RE: Riders back rest ????
They do push you forward....but you do get used to it. They are comfortable for trips.
Old Mar 13, 2007 | 08:50 PM
Bubba Zanetti's Avatar
Bubba Zanetti
I heard another member on this forum say he took the cover and padding off then heated the long posts that slide into the seat part, then bent them back a little. I might try this on mine too cause I get tired of sitting on the end of the gas tank.
Old Mar 13, 2007 | 10:37 PM
todd6751's Avatar
todd6751
speaking from experience....i took mine to the bench vise with a small sledgehammer. just bend the lower part of the legs just above where they insert into the mount. pull the leather up as far as you can and start banging. it's pretty tough steel but trust me, they will bend. now mine is perfect. it took a couple of times before i got it just right. pull the fabric back down and you can't tell. good luck.
Old Mar 13, 2007 | 11:37 PM
SCHARLEY's Avatar
SCHARLEY
Try turning the mount around on the fender. In others words put it on backwards.
That's what I did and it put the backrest about right for me.
Good luck
Old Mar 13, 2007 | 11:59 PM
Kern's Avatar
Kern
If you have it turned around without having the front connected to the frame just above the battery, I could see it buckling up the fender easily if you lean back good. Not to mention putting a nasty dent or scratch in the fender.
ORIGINAL: SCHARLEY
Good luck
Shovelhead
Shovelhead
14
Aug 15, 2012 09:28 PM
SC-Longhair
Apr 1, 2010 07:25 AM
HimeHog
May 27, 2008 06:41 PM
Realeme99
May 4, 2007 11:04 PM
Keith_H
Jul 12, 2006 01:16 AM
