I have an 05 CVO FLHTC and had to remove the handle bars (found a small crack in cutout for internal wiring) .Does anyone know how to dissasemble the 2 clusters that go to harness under fairing. I have them unplugged but trying to figure out how to remove wires so I can snake them back thru bars.
there is a little tang in there that needs to be depressed, then you can draw the wire back out of the connector block take pics or diagram so you get them back correctly
don't forget to shim the front brake switch or it'll break.
