need some help
Old Dec 1, 2013 | 11:13 AM
The painter's Avatar
The painter
Default need some help
Earlier this year I did the 10 k tune up. Then the shop who did the work put a Moc2 air filter on my FLHT 09 STOCK. The bike started running leen ans deminish fuel mileage, like 70 miles a tank.
What I want to know : what will be the best remedy and keeping the Mac2. ?
I was going to add the Thundermax
Old Dec 1, 2013 | 11:15 AM
Veekness's Avatar
Veekness
I would guess that you'd have to have the ECM tuned also to adjust...was that done? Lotsa information in this forum about that, were it me, I'd just turn the job over to someone knows what they're doing, not my long suit, I'll guess it's not yours either...
Old Dec 1, 2013 | 11:26 AM
mkguitar's Avatar
mkguitar
what do you mean 10K tune up? do you mean 10k service?
"tune up" generally means servicing, tuning, altering the induction ( air/fuel) and ignition system.
1.) low MPG doesn't right away indicate the bike is running lean...more the opposite.
describe what mods have been done to the bike - in detail
and describe what driveability/ operation problems you are observing
more details, better answers
mike
Old Dec 1, 2013 | 01:12 PM
The painter
Mike 10k service.
All that has been done to my bike with the exception of adding the Moc 2 air filter. A lot more air. The bike started running leen and the gas milage dropped.
Would going back to stock air filter be best or would dino ture return me the fuel milage. I am more interested in fuel mileage.
Old Dec 1, 2013 | 01:20 PM
mkguitar's Avatar
mkguitar
I'd be surprised if the air filter alone has resulted in a problem, unless the install was buggered.
alot of the Guys here use tuners etc.
I use nightrider.com XIEDS on my 09 FLHTC, they cost under $130
I also have a hi flow intake and exhaust...my mpg was 44 when stock and is 43 MPG now.
I've run this combination over 10,000 miles.
when you say the bike is running lean- what are you observing...and under what conditions, speed, rpms, load ( grade, passenger, extra weight) etc
mike
Old Dec 1, 2013 | 01:34 PM
The painter
before the new air cleaner I was getting 250 miles to a tank on the open road around town I was getting 200.now I'm only getting a hundred forty seven to a tank around town maybe 200 on the open road.
Old Dec 1, 2013 | 02:38 PM
offthewall's Avatar
offthewall
This really doesn't make sense. The air cleaner may have made it run lean if no ECM changes were made. But that would tend to increase mileage not decrease it.
If the proper changes were made to compensate for more air, your mileage will decrease a bit.
Old Dec 1, 2013 | 04:48 PM
jbkrab's Avatar
jbkrab
My bet is oxygenated (winterized) Fuel. This time of year, my mileage drops as well and in the springtime when the EPA says it's OK to use a different blend, my mileage goes back to more normal levels. Most likely your bike is fine.
Old Dec 1, 2013 | 07:07 PM
mgibson61611's Avatar
mgibson61611
But that's a drop of >25%... I'd press the shop for an answer. I'd expect they know what they did, right?
Old Dec 2, 2013 | 03:09 PM
jbkrab's Avatar
jbkrab
I don't think that 25% is that drastic, I see 17% loss on my daily commutes to work 70 miles interstate round trip. So around town, my guess is I'd see just as much loss to winterized fuel at 25%. All of this is just a guess, but it's my story and I'm stickin' to it!
BensonUK
Apr 6, 2015 04:10 PM
BEN-Z
Aug 19, 2014 07:00 PM
12limited
Sep 15, 2012 11:58 AM
AlCherry
Sep 27, 2009 06:46 AM
greginNH
Aug 25, 2009 12:01 PM
