'08 Ultra Classic,69440 miles. Just replaced compensator with latest S.E version.
test ride had noise and grabbing during decel in 1st and 2nd gear.
tried new primary chain tensioner,helped a small bit.
Can feel it grabbing and jerking the drive train during decel in gear.
Hate to continue to throw new parts at problem til I get it right.
Anybody else gone though this? Thanks
Problem not there prior to comp install.assembly of comp and torque checked twice.did not take clutch off.
Will check clutch adj,,would a stretched out prim. chain cause this?
the ramp on the SE comp. is not the same, and if the chain is to tight it make noise or if the chain is to loss it slaps the case if the torqs are set? Tighten compensating sprocket bolt to 155-165 ft-lbs. Tighten clutch hub mainshaft nut to 70-80 ft-lbs.
I just completed the comp. upgrade myself and have no problems. You may need to pull the comp. again and make sure the spacers didn't slip down on the install. The final torque is 175 ft lbs.
