my 2014 SG is nearly ready and actually looking like that :
The hidden antenna Kit is installed, but in rear the holes (one for fm antenna other for cb antenna) is just closed with oval black plastic/rubber cover.
I want to have clean looking rear in that part and asked dealer to install 90200872DST (Filler Strip Kit Solid) ready painted in AW, but he said not possibel. In P&A 2014 i extra slected right parts.
Is it really not possibel or what is failure ?
HD is selling exactly for reason to clean rear fender more or less.
Maybe someone has an can send or better post picture
If you wanted to use the any of the parts you have listed you would be eliminating the running light on the bottom of your rear fender, as it is one piece all the way around. As long as you're cool with that go for it.
those fillers are for road kings, ultras, and maybe road glides - basically every touring bike except the street glide.
as mentioned already, your street glide rear fillers (fascia or something???) anyway, yours is a 1 - piece, you are looking at filler panels that two pieces... and yes, that would destroy your light under the fender. I'm sure you could do it, but it is going to look something like this....
