Power Vision on 14 SG?
Old Jan 8, 2014 | 01:25 PM
BlackSpecial's Avatar
BlackSpecial
Originally Posted by casique
I would get a new mechanic.
^This^.
Old Jan 8, 2014 | 04:37 PM
Bullbutch's Avatar
Bullbutch
Originally Posted by ke5rbd
I have done 3 maps for 14 SG's with D&D and stage 1. Go to the Dynajet website and download and install the software for the PV. After installing the software go to the Powervision program under start Programs menu and do the Update Client. If you have or when it comes in hook the PV to the computer and run the update client. It will tell you to hook it up even if it is hooked up. Follow the instructions as to which ones get updated first. It will put all the new maps in and do the latest firmware updates. Even if from FM need these updates. You will likely have some decel pop with the canned map. This is easily fixed. The 3 that have been done all run awesome. Even if you install the map that comes on the unit, the map I am sending will improve performance and no pop. Nothing to loose can always swap back if you don't like. Went ahead and attached map. Once you get software installed all you have to do is unzip and click on it and it will open in Win/PV just have Win/PV closed first. The only difference between PV1 and PV2 is the 1 is 4 pin plug and the 2 is 6 pin.
Thank you sir. My new PV should be here tomorrow via UPS.
Old Apr 22, 2014 | 09:04 AM
Sam2010's Avatar
Sam2010
no up date uh? I notice in the above 614 cal injector number is 3.34
Old Apr 22, 2014 | 10:41 AM
user 8373900's Avatar
user 8373900
Originally Posted by Bullbutch
I ordered my Power Vision a little while ago for my 14 SG after which I text my mechanic who works at a dealership and does work on the side said he will not install my PV. Said i should have gotten the SERT cuz he's seen motors blow up with these tuners. The bike is and will remain stock aside from D&D exhaust and the Stage 1 air cleaner. Should I cancel my order?
People tend to fear what they no nothing about. Get the Vision and you won't regret it.
Also, put yourself in a Tech's boots. Here he sits with likely $20,000 or much more in tools and schooling. Technology and Government is making you obsolete by the invention of auto tune and implementing EPA mandates. Soon all they will need to know is how to change the plugs or fix the occasional transmission and change tires.
Mark
Old Apr 22, 2014 | 10:52 PM
ke5rbd's Avatar
ke5rbd
You are correct. I have corrected it and changed it on the posted file.
jwhacks
Sep 18, 2016 06:45 PM
JHC210
2014-2024 Touring Models
33
Oct 5, 2015 10:54 PM
Scaffido
29
Aug 19, 2014 04:18 PM
Pyrodex76
70
Jan 30, 2010 01:54 PM
Cheeze
Oct 20, 2009 12:04 PM
