Lights question
on models in which the lighting power runs through the ignition switch ( such as the 2007).
higher watt bulbs may burn out the contacts in the ignition switch...which means you are stranded and have a pricey fix.
if you use relays and wire them to the battery, you can run ultra high watt bulbs ( I was running 120/90 and 2 x 55 on my '95 FLHTC).
alternatively some like the "blueish" bulbs, I find that the contrast at night is not as good, but they seem better of being seen in traffic
the LEDS may have a narrow light beam and some feel that a bike with LEDS is not seen as well in traffic
my 09 has increased quality in the optics ( reflectors), over my early bikes) and so far I've been happy with 60/55 headlamp and 35 w passing lights
my choice is the "xtra-vision" or vision plus type from the auto parts store phillips or sylvania are names you can trust.
AND "watts" is not a measurement of light output- Lumens is.
Watts refers to the electricity consumed by the bulb, lumens is the measurement of how much light you get ( so possible that a 60 watt quality bulb may throw more lumens than a 75 watt poor quality bulb )
mike
I put a higher wattage bulb in mine, and it burnt out just as I was entering an unlighted tunnel. Scarry.
Now run a TL LED Phase 7 that is full metal construction, great reflector and excellent side illumination on dark curvy roads. Wonderful definition for visibility at night.
If you want to be seen in the daytime, some also install lighted trim rings, but have not done so myself.
Lots of options, pretty much depends on what you want to accomplish.
Least expensive way to get rid of the yellow look is to install higher temperature bulbs. Going too high into the blue spectrum looks cool, but you can't see worth a darn.
