Urgent help with 98 Electra Glide
Old Jan 20, 2014 | 05:00 AM
Big Trev's Avatar
Big Trev
You really aren't paying attention are you, it's a different ignition switch
Old Jan 20, 2014 | 06:59 AM
klimoman's Avatar
klimoman
Originally Posted by Citoriplus
Don't worry about it.
You were not the person that I intended to address with that note about illegal manuals.
If you read that posting I edited everything he put in there about one and substituted my message about lawyers and on line or digital manuals.
Just delete my post. I do not want you typing YOUR message under my username.
Old Jan 20, 2014 | 08:08 AM
UltraNutZ's Avatar
UltraNutZ
amazes me how many people simply jump in a thread and start posting without reading the OP's question(s)
As mkguitar stated, 1) this is NOT a typical FLH ignition switch found on today's bikes and 2) this is an INT'L model bike.
Old Jan 20, 2014 | 08:44 AM
Nute's Avatar
Nute
As Mike suggested the left hand drill bit to remove the screws. Here's and even easier method. Get the "Grabit" stud removers. They are easier to use and find than the left hand twist drill bit. You won't confuse them down the road with your standard right hand twist drills.
Old Jan 20, 2014 | 02:30 PM
Steben's Avatar
Steben
Hi all, have read through and yes bars are loose. I can sit on bike and move backwards and forwards with a little pressure. I am not able to see pictures attached (not even my own) as forum says I do not have permission.
I have managed to tighten but took some bending of plastic but done. Ignition was not being nice.
Have put her back together but now have a short in wiring. With bat wing off lights fine. Put it back I have driving lights no headlight and high beam light is on. Another job for after work tonight.
Cheers all
HBGB89
Jun 2, 2024 12:26 AM
17RGlideSpecial
Mar 26, 2019 10:30 PM
Ultra Pearl
Jun 11, 2013 10:43 PM
kerrychaisson
May 23, 2012 08:59 PM
Vdogged
Jan 25, 2010 08:35 PM
