Oil pump alignment
Old Apr 29, 2025 | 08:55 PM
  #41
Highway Handler's Avatar
Highway Handler
Originally Posted by Tat2carson
when we put the better cans in the 02 fuel inj bikes does it have to be tuned. Or can we drop the cams in n go
in new to twin cams I’ve only had carb evo motors in the past
I have Rinehart True Duals and a stock air cleaner. I did not re-tune and my bike runs strong. Spark plugs look good and no decel popping. Different cams will be a different story. Andrews Products N26 is probably OK also.
Old Apr 29, 2025 | 09:22 PM
  #42
Spanners39's Avatar
Spanners39
Originally Posted by just plain john
I'm installing a used cam plate from an 07 TC96 into my 05 TC88 in conjunction with a conversion cam. Will it be necessary to align the pump? I don't have the alignment pins is why I'm asking.
Absolutely you do! and rotate the motor while tightening the bolts. Evo lifter block pins are the same tool
Hooter1
Exhaust System Topics
14
Feb 9, 2015 10:59 PM
Sandcrab
Dec 22, 2014 09:35 AM
Jrindagame
General Topics/Tech Tips
Dec 2, 2013 03:42 AM
rcrook
Jun 19, 2012 09:24 PM
skully1200
Feb 27, 2012 05:29 PM
