High performance cam replacement info needed.
Old Feb 7, 2014 | 08:45 AM
harleytuner's Avatar
harleytuner
Originally Posted by mdanehart
I purchased this beautiful 07 113ci SG with only 9000 miles on the clock.
The previous owner is a Law Enforcement Officer who had the engine built to his specs, go fast.
The bike runs real strong above 4 RPM, at that point it's bait for the State Troopers.
I ride alone and never go past 70 MPH on a good day, licensed as a Mortician I have seen the ugly side of motorcycles accidents.
With the attached specs that the former owner displayed can somebody suggest cam that would provide great bottom and midrange with the arm pulling torque that I am looking for.
The engine is a 113 ci bored and balanced by Roeder HD.
Motor also has timkin upgrade bearing installed & welded..
10.5 compression
625 S&S gear drive cams
Fueling Billet Cam Plate (eliminates flex in cam plate this mod alone is worth about 5 hp)
Fueling lifters
HPI push rods, intake and throttle body 52 mm
Screamin Eagle 110 Heads with Automatic Compression Releases
Updated flashed computer for ACR in heads and motor upgrades
Jims rocker boxes for extra clearance for valve train
Jet Scream intake screen
Arlen ness stage II air cleaner and filter
Thundermax Self Tuner
6 row JAGG oil cooler
Vance and Hines 2 into 1 exhaust
Energy One HP extra plate clutch kit
Throttle Up Stablizer...
Thanks in advance.
I'm trying to put my head around this build, it's not ringing a bell with me. But if we built the motor George Roeder will remember it. You might want to give him a call (419)465-2247 and ask what he recommends as far as cams go. He will know what cams should work best with the heads, especially if he did the P&P work on them.
quija
Mar 12, 2021 03:28 PM
SJ12DS
Engine Mechanical Topics
27
Jul 24, 2016 03:46 PM
ahmoose
Dec 22, 2014 12:21 AM
Kaycee
19
Feb 23, 2012 09:42 PM
expolice
Exhaust System Topics
Oct 9, 2008 08:06 AM
