Replacing Head Pipe gaskets?
Old Feb 3, 2014 | 09:15 AM
cpita's Avatar
cpita
Default Replacing Head Pipe gaskets?
Ordered a stock decatted H/P for my 11, which gaskets should I use when I replace them?
Old Feb 3, 2014 | 09:22 AM
KCFLHRC's Avatar
KCFLHRC
The stock gaskets work fine, no reason for anything else.
Old Feb 3, 2014 | 09:27 AM
TUCCI's Avatar
TUCCI
If youve never had the header off you can reuse the stock ones. When I put the VHDDs on I used oem gaskets and they worked fine. You need to tap them in gently or they will squish, even if you freeze em like its been suggested.
Old Feb 3, 2014 | 12:29 PM
SmokeyJoe101's Avatar
SmokeyJoe101
Freezing helps out. Just be careful not to deform them
felix27
Jun 10, 2016 08:04 PM
Chunky Monkey
Exhaust System Topics
Feb 8, 2015 08:47 PM
wrenchguy24
2014-2024 Touring Models
Jan 1, 2015 11:10 PM
WestTexasRanger
Feb 21, 2013 04:13 PM
TickTock
Nov 6, 2010 07:46 AM
