dead ultra
Old Feb 9, 2014 | 08:28 AM
ZUTEDUFF's Avatar
ZUTEDUFF
Drew...
When mine was having problems i found one of the coil wires were also corroded so bad at the coil that it wouldn't go all the way inside of the hole....that was also causing a problem..check those wire at the coil...also check the fuel pressure...you need a gauge and adapter to check by the book, but what I did was turn on the switch, let the pump build up and then i pulled the line off of the pressure side on tank...(make sure you wear safety glasses.) If the pump is getting up to the correct pressure, gas should shot out every where like a water leak in a faucet or it will be so tight the line won't come off or will be extremely hard to get off. Man those gremlins can be a PITA......Hope you get it going and keep us up to date....
Old Feb 9, 2014 | 10:17 AM
leon anthony's Avatar
leon anthony
My 08 ultra did that I pulled the plugs when it would not start and put some gas in the plugs holes put the plugs back in and it fired it did not run but it fired so that makes it a not getting gas problem after much head scracthing I finely found out it was a defective quick disconect at the tank
Old Apr 4, 2014 | 12:17 AM
drew macmillan's Avatar
drew macmillan
5th Gear
Default dead ultra
Hey guys ,just saying I have been busy neglecting bike problem. but ready now to fix this mad ultra issue! will report back soon. thanks
Old Jun 14, 2014 | 07:40 PM
drew macmillan
5th Gear
Default bad ultra
believe it or not still no spark. tested every thing I think ecm not flashing to ground but power going to coil ? help dealer ship booked for months out of town anyway bastards
silverbullitt
2014-2024 Touring Models
17
Feb 17, 2014 09:26 PM
tarheelrdr
Nov 1, 2010 10:06 AM
98-Fatboy
Sep 13, 2009 09:57 AM
BadBobOk
Jul 27, 2007 10:52 PM
Ultrasweet
May 29, 2007 10:54 AM
