Intermittant charging
Old Mar 11, 2014 | 11:12 AM
bobbott's Avatar
bobbott
Stage II
Default Intermittant charging
My 08 Classic has started charging at 10 volts then up to 14 then back to 10, restart it charges 14 and is OK next time it starts and charges at 14, 5 miles later back to 10, restart its back OK.
Taking everything apart today clean connections and grounds, any ideas?
THX. Also horn quit working.
Old Mar 11, 2014 | 11:15 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
My quick guess is loose battery cable connections at the battery.
Old Mar 11, 2014 | 01:15 PM
Nute's Avatar
Nute
Loose connection (Battery Terminals, Voltage Regulator). If none of these Voltage Regulator or Alternator may be dying. I'd also have a look in your transfer case and make sure you compensator isn't loose or showing signs of dying.
Old Mar 11, 2014 | 01:34 PM
artc's Avatar
artc
Same thing happens to my 08. It was a bad gauge. Check volts at battery to see if it matchs what the gauge says.
Old Mar 11, 2014 | 07:25 PM
bobbott's Avatar
bobbott
Stage II
Pulled codes, read low voltage here and there and throttle position sensor.
tightened all connections at battery etc, checked all fuses spray cleaned all harness connections etc. Started up and seems OK but is now at 1K rpm idle.
Taking it out in the morning and ride.
Old Mar 11, 2014 | 07:55 PM
Timpechos's Avatar
Timpechos
I think there supostoidle at 1000 rpm?
Old Mar 11, 2014 | 08:01 PM
steelerdude1's Avatar
steelerdude1
+1 idle should be 900-1000 rpms
Old Mar 11, 2014 | 08:02 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
if the idol is changing,that would be the tps code.
Old Mar 13, 2014 | 02:45 PM
Nute's Avatar
Nute
If you are showing TPS codes check the connection right at the Throttle Body behind the AC. Common problem with the Throttle-By-Wire. There's a factory TP out on this as well it is dealt with in the 09 maintenance manual.
Bagger G
Electrical/Lighting/Alarm
Oct 16, 2017 02:26 PM
richard567
EVO
Aug 23, 2016 06:59 PM
vickers1
Aug 1, 2013 09:48 AM
wils5150
Apr 29, 2013 08:49 AM
magflh
EVO
Jul 20, 2009 07:44 PM
