idle adjustment
Old Mar 19, 2014 | 04:46 PM
jmn1960's Avatar
jmn1960
Question idle adjustment
my friend has a 2001 ultra ,, mine is the same but a 2005 ,, his is only idling at around 600rpm and it should be around 900 ,,?? is how to adjust the rpm's up , i do have a manual for mine and i am sure they are the same ,, but i have not looked into it yet ,, tried the cables last night ,, but only got stiff on the return of the throttle return ,, so i out it back to where it snaps back smothly ,, is there a adj. screw behind the a/c plate ??? or is it more complacated than that ?? will get manual out this weekend and see ,,, just getting a heads up on this ,.
thanks mike
Old Mar 19, 2014 | 05:17 PM
doc ock's Avatar
doc ock
If they are EFI with the Delphi system then there is no adjustment. Does the bike have a EFI controller other than stock? 2001- 2005 might not be the same. I'm not sure the exact year M&M systems where discontinued.
Old Mar 19, 2014 | 05:39 PM
jmn1960's Avatar
jmn1960
dont know ,, but they are both the 88 eng , sequencil injection ,, or how ever u spell that
Old Mar 19, 2014 | 05:56 PM
SafetyMan's Avatar
SafetyMan
EFI bikes don't have a "screwdriver adjustment"
They require a flash tuner to adjust.
If you don't know whether it has a carburetor or not, you shouldn't be monkeying with it...
Just sayin.
Old Mar 19, 2014 | 06:42 PM
jmn1960's Avatar
jmn1960
safety man ,, not carbed as mentioned,, and i like to monkey with things ,,
i will get the manual and take a gander this weekend ,, just need to bump it a couple hundred rpm's
thanks
Old Mar 19, 2014 | 07:00 PM
Ultrascott's Avatar
Ultrascott
2001 is a magnetti marelli fuel induction and isn't the same as your 05. There is a screw hole behind air filter cover that you adjust it by. Search for idle adjustment on magnetti marelli systems. Not hard
Old Mar 19, 2014 | 07:02 PM
lt1-xjs's Avatar
lt1-xjs
thanks
A simple search will reveal all you need to know. I Googled 2001 Ultra idle adjustment. Make sure the bike is totally warmed up.
Old Mar 19, 2014 | 07:06 PM
jmn1960's Avatar
jmn1960
ultrascott & it1,, thanks looks easy enough ,,
thanks again
Old Mar 19, 2014 | 08:38 PM
bigheadted's Avatar
bigheadted
Just sayin.
OH OH SafetyMan Look before you leap !!!
I thought all efi was non adjust as well so I learned sumpin
S
Old Mar 19, 2014 | 08:44 PM
HOGILAC's Avatar
HOGILAC
pretty simple to make adjustments if you have a tuner..., if so call the manufacture for assistance
thanks mike
