H-D New Loud Replacement Horn
Old Mar 24, 2014 | 04:55 PM
highwayking's Avatar
highwayking
Default H-D New Loud Replacement Horn
Has anyone installed the new loud side mount replacement horn p/n 69060-90G? Price doesn't seem too bad, but before I order one, I was just curious if you can really tell a difference from the puny stock horn. Also, the description says it's an "easy" replacement. I've seen that before and I've found out the hard way that it isn't always easy.
Old Mar 24, 2014 | 05:07 PM
mkguitar's Avatar
mkguitar
you'd probably do as well at your local auto parts store.
I use an air horn on my bagger ( H-D I bought used, I wouldn;t pay retail for one- i had a Howies but it died pretty quick.
I use an ebay $8 6 volt horn on my FXR.
mike
Old Mar 24, 2014 | 05:59 PM
Miller5463's Avatar
Miller5463
It is the stock horn on the 14's. It is noticeably louder than the other stockers. Still doesn't compare to my buddy's '12 Gold wing...but I don't want a gold wing LOL.
Old Mar 24, 2014 | 06:04 PM
mikelikesbikes's Avatar
mikelikesbikes
Wanna follow this as the horn on my RG sucks. Funny thing is the last HD horn I put on my Road King is quite loud. It being an 01 I have had about 5 horns on it. Mostly stock except a couple so gotta wonder what HD does with their horns.
Old Mar 24, 2014 | 06:18 PM
btsom's Avatar
btsom
There is a "tuning" screw on the horn and if your horn is weak, you can try turning that screw a little in each direction. One way will make it louder. The horn on my son's 11 Road Glide Ultra was louder than the one on my Road King so I tried the screw thing and they are about the same now. It is a small phillips head screw held in adjustment by a lock nut. The horn will get louder and louder until it won't work any more. Then turn the screw back a little, tighten the lock nut and put it all back together. The horn must be made by the lowest bidder but can be made to work pretty well.
Old Mar 24, 2014 | 06:23 PM
Street-Glide's Avatar
Street-Glide
You need a minibeast! Loud and looks great!
Old Mar 24, 2014 | 06:56 PM
rmc115's Avatar
rmc115
my horn on the 14 died already, another great idea poor execution. Mike
Old Apr 9, 2014 | 07:00 AM
LiveRound's Avatar
LiveRound
6th Gear
I got the Wolo Badboy horn for $60.00. It was loud. I was warned by a friend it would have a short life and sure enough it lasted about 1200 mi and died.
Old Apr 9, 2014 | 08:49 AM
jdvorchak's Avatar
jdvorchak
I went with a 14 HD horn for about $40 from the local dealer. Easy install and it is noticably louder. But still not loud enough.
I think the Gold Wing horn is louder because there are two of them. My 01 GL1800 was so loud it scared people... Just what I wanted.
Old Apr 9, 2014 | 09:37 AM
Joe12RK's Avatar
Joe12RK
I bought the hi/lo pair of Fiamm Freeway Blaster horns, they were only $15 ea. The hi/lo combination is what makes car horns so noticable. I tested them last night and found the lo one sounds the same as the stock 2012 horn. So no need to swap that one. I'm going to install the hi horn under the left side cover with a relay.
