1985 FLHT Ignition problem??
Old Mar 29, 2014 | 09:26 AM
Rick Pappy Stief's Avatar
Rick Pappy Stief
6th Gear
Default 1985 FLHT Ignition problem??
I just bought a 85 FLHT . Is there a problem with the ignition switch I should know about? When I go to start it it's completely dead no lights, horn, nothing. Where should I start looking for the problem? New battery, all connections are clean and tight.
Old Mar 29, 2014 | 09:38 AM
0ldhippie's Avatar
0ldhippie
Electrical troubleshooting 101. Get out your test light and follow the wires...
Old Mar 29, 2014 | 09:44 AM
Rick Pappy Stief
6th Gear
I appreciate that....lol I rode it yesterday and it ran fine, when I went to start it up again there was nothing.
Old Mar 29, 2014 | 09:46 AM
Rick Pappy Stief
6th Gear
For me trouble shooting electrics might as well be quantum physics ....lol
Old Mar 29, 2014 | 09:50 AM
Jackie Paper's Avatar
Jackie Paper
Check the battery and connections again. It another day. Things get loose. That's more likely then the switch. If the battery is drained, need to check amp draw with key off.
Old Mar 29, 2014 | 10:58 AM
mkguitar's Avatar
mkguitar
It's similar to plumbing....
IF high watt bulbs are used, the contacts in the ign switch can burn out, and it needs replaced. This can be expensive.
They can just burn out ( arcing causes pitting and poor contact which in turn causes more arcing).
try wiggling the switch when the bike is dead.
or try wiggling it when the bike is idling, see if it dies.
there is also a circuit breaker on your bike- they get weak, replace that with a 40 or 50 amp breaker- that's cheap and easy.
you can test that with a trouble light when you have a problem...if you have voltage before the circuit breaker, but not after then there's the problem.
so the water is flowing in the pipe to the valve ( circuit breaker) if you have water on the other side of the valve, then you know it is open, if not it is closed.
same procedure with every part...if you have power to the ignition switch, but none coming out of it then there is the problem.
all of this needs a good known battery and cables, in addition there should be a ground strap from the inner primary case by the tranny to the frame.
Mike
Old Mar 29, 2014 | 11:42 AM
budsbike's Avatar
budsbike
I also have a 1985 FLHTC that had the exact same problem. It ended up being the positive cable from the battery to the starter solinoid. The lug at the solinoid end stress cracked but the heat shrink made it look like it was connected. That part is no longer available from HD so I re-soldered a new lug on it and its still working fine today. Either way the problem can't be to far from the battery if everything is not working. Good luck!
Old Mar 29, 2014 | 01:11 PM
Rick Pappy Stief
6th Gear
Thanks for all the replies. I jumped the solenoid and the motor turns over strong but it won't fire. I'll check the breakers next (when I can find them). Not sure if their behind the head light or under the seat.
Old Mar 29, 2014 | 01:36 PM
Def Mute's Avatar
Def Mute
I'm having dejavu...
didn't I see this thread somewhere else?
Old Mar 29, 2014 | 01:47 PM
Rick Pappy Stief
6th Gear
You sure did and all your help is appreciated !!!!!!!!!!!!!!
