Kickstand loose
Old Apr 2, 2014 | 09:58 AM
CoachJR's Avatar
CoachJR
Default Kickstand loose
It's flopping around a little, and dragging even in "normal" cornering. Is this just a "change the spring" or "tighten a screw" fix? Thanks in advance.
Old Apr 2, 2014 | 10:09 AM
user 8373900's Avatar
user 8373900
You need a new spring most likely. Most dealers have them in stock. Take the bolt out of the top remove the stop, rotate the stand forward, remove damaged spring, install new spring re-assemble. 10 minutes tops. You will need someone to hold the bike up or have a jack available.
Old Apr 2, 2014 | 10:50 AM
riderideride's Avatar
riderideride
I'll agree with onedownand5up. It probably made contact with a speed bump or something, denting/damaging it a little. They are cheap at the dealer, like $5 or $8, so get a few of them. When apart also lube the jiffy stand's leg, where it goes into the bracket.
Old Apr 2, 2014 | 11:17 AM
RaceFace's Avatar
RaceFace
It's the spring. I've even seen on here people carry a spare spring on their scoot.....just in case.
Old Jun 24, 2014 | 09:08 AM
K Wyle's Avatar
K Wyle
Cool spring replaced..
I damaged my spring going over a curb leaving my favorite parking spot... I'll never try that again.. Crazy thing is I had just did it the day before but at a much slower speed..
I followed the steps below and it was a piece of cake. I loosend the bolt enough so that the stop plate would clear and let me rotate the jiffy stand all the way forward to connect the new spring.
Old Jun 24, 2014 | 10:16 AM
EasternSP's Avatar
EasternSP
I was loading my RG into a truck a few years ago when it broke down on the road. The spring snagged on the loading ramp and stretched it out to about a foot long. I replaced it with the chrome version of the H-D spring but that didn't last long at all. The spring would not recoil all the way and that left the Jiffystand swinging a bit free. Put a regular H-D spring on it and all has been good for a couple years now.
Old Jun 24, 2014 | 11:45 AM
103 sedona orange's Avatar
103 sedona orange
I suggest you get a new spring.
Old Jun 24, 2014 | 11:55 AM
SeaZund's Avatar
SeaZund
agreed, stay away from the chrome...something about the plating process (the elevated heat perhaps ?) affects the molecular structure of the metal: ultimately weakening it.
Old Jun 24, 2014 | 12:46 PM
ironhead3fan's Avatar
ironhead3fan
Ditto, get a new spring, most any dealer should carry one.
Old Jun 24, 2014 | 02:06 PM
SafetyMan's Avatar
SafetyMan
If you find it tough to stretch, put a coin between each coil, that will stretch it out without the jeeeezziss factor...
saltydawg
May 2, 2019 09:08 AM
Principle
General Topics/Tech Tips
Mar 20, 2016 06:25 AM
bowman0429
Mar 14, 2016 10:31 AM
CalypsoNotch93
Dec 17, 2014 05:21 AM
rockon
Nov 18, 2008 04:36 PM
