How Much Oil
Old Apr 4, 2014 | 06:56 AM
Wild Card's Avatar
Wild Card
Originally Posted by foxtrapper
I don't dispute it, but I sure don't understand it. My breathers are from my engines cylinder heads, not the oil tank (though there might be one there also). Why would having the oil tank full cause oil to breath out of my cylinder heads?
If they don't vent the top end it could build pressure. All motors are vented in the top end auto industry its called a PCV valve.
Old Apr 4, 2014 | 07:40 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I understand crankcase ventilation quite well. What I don't understand is why filling an oil tank connected remotely to the engine causes oil to drip from those cylinder head vent tubes.
Old Apr 4, 2014 | 07:50 AM
hardheaded's Avatar
hardheaded
i put 3 quarts 14 ozs. in my 12 streetglide and it brings the level right to the full mark when hot. never had any blow by or problems doing this.
Old Apr 4, 2014 | 07:54 AM
teedubya's Avatar
teedubya
HD service manual will say to fill with 3qts, start and idle to check for leaks and fill oil filter. Turn engine off check oil level and fill to midway mark. I have no idea why some HD shops continue to fill to full mark. Pisses me off to no end when I find it done in this manner.
Old Apr 4, 2014 | 07:57 AM
continentaldrifter's Avatar
continentaldrifter
WOW............this is a surprise to me as i have been putting 4 quarts in since the Evo's.....never once had ANY blowby....
Old Apr 4, 2014 | 08:02 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Originally Posted by the warden
Always fill it to the halfway mark on the dipstick, which generally turns out to be about 3.5 qts. That said, I use the Scavenger System, so once the oil starts running clear I then continue to fill until half way between add and full. Never get oil blow by.
+1 on this 4.0 qts. & 3/4 on the stick
Old Apr 4, 2014 | 08:06 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
If you plan to fill the oil filter first then install it on the bike without a mess, you will need a couple of "Bruno's" to hold your bike up in the air sideways!
I always fill the oil filters on vehicles that have the oil filters mounted vertical.
Horizontal mounts, like on our Harleys, will pose a challenge to not spill, Bro!
"Thumb it" and let us know how it works out for ya!
strych9
Engine Mechanical Topics
Aug 1, 2020 03:10 PM
Chicago Ken
Jul 18, 2019 12:34 PM
kirby
Jul 25, 2010 09:04 PM
mac1014
Exhaust System Topics
Jun 3, 2010 02:27 PM
nivram39
Feb 22, 2008 11:13 AM
