Infotainment system won't shut down
Old Apr 5, 2014 | 06:38 PM
Unfazed SGS's Avatar
Unfazed SGS
6th Gear
Cool Infotainment system won't shut down
the infotainment system will not shut down? it stays on even after i power it off. restarted and the radio stations say searching, nav says not ready.....nothing is working but it wont shut down.
Old Apr 5, 2014 | 06:41 PM
Bulldog13's Avatar
Bulldog13
Take off the left side cover and pull the red 50 fuse, wait a few minutes and put it back in. Should work after that, but you should check the software to see if it's up to date.
Old Apr 5, 2014 | 07:05 PM
Dawg 689's Avatar
Dawg 689
Can't explain the radio issue, but it does require a few seconds for the NAV to boot while searching for satellite reception
Just my experience
Old Apr 5, 2014 | 07:14 PM
Unfazed SGS
6th Gear
thanks, i pull the fuse. the system is on but not responding to any commands? .... tough day....finally nice weather and i get a screw in the front tire. dealer wants to replace tire........bike has 250 mile on it. when to a tire repir and they said come back tomorrow they have to talk to their boss. dunlop allows for repair so not sure what the problem is
Old Apr 5, 2014 | 07:20 PM
Unfazed SGS
6th Gear
pulled red fuse and it shut down. thanks Bulldog13.......will start up tomorrow and let you know if it happens again.
Old Apr 19, 2014 | 09:42 PM
jeff53346's Avatar
jeff53346
Stage I
Thanks! I was about to pull the battery cable. Your way is much easier.
Old Apr 20, 2014 | 07:09 AM
wenterkin's Avatar
wenterkin
Had it happen one time just the other day. Radio stayed on after shutdown and turning off ignition. Turned volume all the way down and came back to it about 10 minutes later. System had turned off and everything was fine. Hasn't happened since.
06SGWA
2014-2024 Touring Models
39
Mar 4, 2019 03:19 PM
llewop
Electrical/Lighting/Alarm
Sep 23, 2015 08:31 PM
blackswampharley06
Mar 31, 2012 10:34 AM
ToadsUltra07
Jul 29, 2007 11:36 PM
fiddledicksr
May 21, 2007 07:04 PM
