04 Electra wont start
Old Apr 8, 2014 | 10:51 AM
jettech89's Avatar
jettech89
5th Gear
Default 04 Electra wont start
I went out to get on the bike to ride into work this morning and the damn thing wont start, everything comes up and it just clicks, the lights dim so it's getting a current draw but it wont crank. Is it possibly the starter? Bike is an 04 Standard if that matters.
Old Apr 8, 2014 | 10:57 AM
CGLTD's Avatar
CGLTD
check the starter relay under the seat by the rear fender.
edit: Nevermind. I didn't read that it clicked.
Old Apr 8, 2014 | 11:02 AM
mkguitar's Avatar
mkguitar
probably your battery is flat, 2nd check is cables.
click under side cover ( not sure on your models, my evos were under right side cover, my 09 is under left side cover on fuse block) shows starter relay is working, that shows that all the wiring to the switches is good.
clicking/chattering solenoid shows the starter relay is also good, but that there is not enough current to turn the starter ( it could also be damaged solenoid- see below- easy to fix if you have ever worked on a chevy)
2 cautions:
allowing the solenoid to chatter will carbon the contact disk, possibly pitting the surface due to arcing, requiring repair if you allow to this to happen alot.
if the starter "whines" but doesn;t turn, that is the sound of the windings heating up, release the button or they will burn= $$$
If you think the starter relay or handlebar wiring/switches are bad, run a jumper wire from the battery + to the solenoid terminal where the green wire attaches- this will bypass all that stuff and IF the solenoid and starter have good power from the battery, magic will happen
mike
Old Apr 8, 2014 | 11:48 AM
jettech89's Avatar
jettech89
5th Gear
Thanks for the help guys.
Old Apr 8, 2014 | 01:47 PM
grbrown's Avatar
grbrown
Also use a multimeter to check your battery condition. It should read over 14 volts at rest, not drop too much when pressing the starter. If you have any doubts about battery charge, read the two Stickies in the Tech Electrics section. That will identify a weak battery or faulty charging system and the cause.
Old Apr 8, 2014 | 03:10 PM
Pix's Avatar
Pix
And let us know what you find out!
Old Apr 8, 2014 | 03:13 PM
jerseyjeff62's Avatar
jerseyjeff62
Lights dim when cranking....low voltage either bad battery or loose or dirty connections
Old Apr 19, 2014 | 06:32 PM
jettech89's Avatar
jettech89
5th Gear
Somewhere along the way the nuts on the leads to the starter got forgot or they vibrated off, lost or missing parts aren't covered by the HD extended warranty, go figure.
Old Apr 19, 2014 | 08:18 PM
mike canuk's Avatar
mike canuk
If your bike ran fine before, and you had no problems. I would check for loose connections, at the battery, chasse, starter solenoid, starter. Making sure your battery is in good shape 12.8 vdc and your voltage drop isn't lower than 10.5 volts when cranking it...
Old Apr 19, 2014 | 09:31 PM
Birdman2778's Avatar
Birdman2778
Prob the battery. They seem to die at will
matt_m_72
Apr 8, 2019 08:47 PM
PBL
Engine Mechanical Topics
Jun 19, 2018 10:02 PM
kevinviz
Mar 6, 2013 11:57 AM
paul d
EVO
18
Aug 30, 2010 09:15 AM
dirty78ironhead
Ironhead
Feb 8, 2009 10:59 AM
