front wheel wobble
Old Apr 8, 2014 | 03:57 PM
Bushy's Avatar
Bushy
Question front wheel wobble
I recently had my front tire replaced due to excessive wear, now I have a a slight wobble at 23-30 MPH... all points lead to neck bearing.. anyone else had a issue.. I have a 2012 Limited
I also have the ESP
Old Apr 8, 2014 | 04:06 PM
jdvorchak's Avatar
jdvorchak
Usually if a problem crops up it's a result of the last thing you did. You just had the tire changed and you don't think that might be the problem? Inspect it carefully looking for the bead to be mounted evenly all the way around both sides of the wheel.
Old Apr 8, 2014 | 04:33 PM
hog95023's Avatar
hog95023
My bike did the same damn thing.
Old Apr 8, 2014 | 05:09 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Start with the tire pressure and and then see if it is balanced and how.
Old Apr 9, 2014 | 09:54 AM
Bushy's Avatar
Bushy
I just returned from dealer....I have a bent Rim.. tire is already showing wear.. replaced under ESP
Old Apr 9, 2014 | 10:26 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I wonder how you bent the rim? Low pressure combined with a huge pothole?
Old Apr 9, 2014 | 10:29 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Or a ham fisted tire changer.
Old Apr 9, 2014 | 11:23 AM
Hogpro's Avatar
Hogpro
Former Sponsor
If so he would have to be extremely ham fisted.
Old Apr 9, 2014 | 09:35 PM
jdvorchak's Avatar
jdvorchak
Actually while breaking the bead the wheel could easily be bent if the guy didn't know what he was doing or was not careful.
Old Apr 10, 2014 | 08:54 AM
Bushy's Avatar
Bushy
i realized a few months back I hit a pot hole and that caused me to sideswipe a raised man hole cover,,I inspected the rim and heard no air so I thought it was ok... now we find out it was damaged and threw the tire off.. hence my wobble at slow speeds,
new tire and ordered rim.. hope its as good as new
