De- Baffle
Old Apr 12, 2014 | 08:59 PM
Tim_Sr's Avatar
Tim_Sr
Default De- Baffle
Is there any good way to loose some of the baffling in stock 01 ultra classics mufflers? I want my bike louder but can swing a new set of mufflers just yet, just recently got the bike.
Old Apr 12, 2014 | 09:56 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
I wouldn't advise that you do that.
I'm not sure of how the OEM mufflers come apart but if you remove the baffles that bike isn't going to run very well.
If you can just remove some of the packing it should be run ok but leave the baffles alone.
Old Apr 12, 2014 | 10:29 PM
Ben221's Avatar
Ben221
I debaffled my stock pipes on my 13 and it runs good. There are some posts on how to do this. Not sure my are the same as yours.
Old Apr 12, 2014 | 10:37 PM
Tim_Sr's Avatar
Tim_Sr
The packing is what I meant thanks looks like the only way to do it is to cut the muffler so I may just live with it for awhile
Thanks for the info
Old Apr 13, 2014 | 01:10 AM
mkguitar's Avatar
mkguitar
Supertrapps engineers are of the opinion that removing packing may cause reduced performance.
in short the suddenly larger exhaust tract means that the gasses loss velocity, gasses entering the area where the packing was can slow, eddy and even reverse.
the whole idea of a performance exhaust is to have good gas velocity from exhaust valve to muffler tip
alot of guys hack, drill bang etc to stock mufflers- usually on the way to getting something better.
if you are going to modify, remove from the bike, some guys damage the headers twisting and banging on the mufflers, the Y pipe at the rear head seems to crack when tortured
mike
Old Apr 13, 2014 | 08:21 AM
Tim_Sr's Avatar
Tim_Sr
Default Thanks
Thanks guys ive decided to just live with the quiet until I can get the mufflers. I wouldn't want to make blackie (the bike) mad at me for drilling and hacking on her
Old Apr 13, 2014 | 08:35 AM
steelerdude1's Avatar
steelerdude1
Removing baffles will not cause any harm. Lots of guys run unbaffled slip ons or drilled out stockers without issue.
Old Apr 13, 2014 | 08:58 AM
northeimcustom's Avatar
northeimcustom
if you use the 3'' hole saw method, id suggest ear plugs too! and a nice sharp bit!
i used a dremel with a small cut off wheel and cut around the perimeter where the hole saw would cut. that worked easier for me.
OP: the longer you hesitate on doing this, the more your going to think, boy, why didnt i do that sooner?!
Old Apr 13, 2014 | 10:38 AM
bigheadted's Avatar
bigheadted
Another option is some late model take offs. I ran a set from a 2008 96" for a while and they sounded better than the stock 2004 ones. My baby Brother is sending via the Dad delivery motorhome a set of 2013 103" from his new bike and I will try them for giggles.Currently have Supertrapps. I would keep an eye on your local craigslist or even run an ad looking for some, you sometimes see slipons real cheap.
Road Star
Milwaukee Eight (M8)
26
Jan 26, 2019 08:31 AM
junglejoe
2014-2024 Touring Models
26
Nov 1, 2015 06:16 AM
John Bakker
Jul 29, 2011 02:11 PM
jaysonL
Jun 9, 2008 01:08 PM
jerseyjeff62
Jun 7, 2007 10:57 AM
