I just finished installing my "homemade" air ride lowering system and so far I like it.
I have read in some recent threads that it is critical that the rear shocks be mounted verticaly in line from top to bottom as viewed from the rear. meaning while viewing it from the rear , the shock should appear straight up and down and not to lean outward or inward. I know from the side view the top of the shock will be forward of the rear.
My concern is that the upper part is closer to the bike than the lower is. Is this an issue that I should be concerned about? Do I need to add spacers or washers behind the shock to adjust for this alginment? What should I use to measure to make sure its correct?
Bolt up the bottom of the shock without inserting the top bolt. Then pivot the swing arm up so you can align the top mount holes and measure the gap; that's the thickness of the spacer you want.
Just need spacers so they stand up straight. You might need a longer top bolt though for the added distance. Has to be set completely into the threaded hole in the frame.
By not being vertical your shocks are being subjected to a lateral load, which will cause premature wear over time, possibly even binding, as they are opposing each other while your swingarm is going up and down. The chaps above have covered using spacers!
I'll toss out a caution regarding shock alignment. The claim is based on everything being perfectly positioned and square throughout the range of motion of the swing arm. That's actually pretty unlikely. Having the shock nice and square at the fully extended position does not mean it's nice and square when compressed. There's a reason the shocks have rubber bushings.
The alignment of the shock has to be front to back of the bike. In other words, if you stand behind the bike and look at the shock, it has to be straight up and down. When standing next to the bike and looking at it, the shock will be leaning forward. The eyelets at the top and bottom of the shock should not be forced, i.e. side to side of the bike.
