Not Happy with New Cams
Old May 1, 2014 | 06:41 PM
pounder35's Avatar
pounder35
Default Not Happy with New Cams
Hello
I have a 99flhr and with 37k on it so I said it's about time to do a cam swap Glad I did as the tensioner shoes and old 203 cams were pretty wore out
Don't know if I rushed into putting the Fueling 543 cams on my 95 kit (I'm thinking maybe the cam is to big for the 95 ) Dont have the smilin grin like I did bfore
All as I know is I have a huge trq dip right where it counts
Could it be the Thunderheader or is it the wrong cam ??
as far as numbers go there not to bad
Got 91hp and 102 tq on
Can anyone reccomend me a better pipe Someone was saying go with a stock head pipe and a better slip on
Old May 1, 2014 | 06:51 PM
mkguitar's Avatar
mkguitar
the TH 2/1 is a torque pipe.
if you have a hole there then it could well be the cams.
or a retune is required, fuel and ignition timing to match
carb/efi?
mike
Old May 1, 2014 | 07:45 PM
Guntoter's Avatar
Guntoter
The Fueling site seems to to be very low on specs for that cam, but they state it needs performance valve springs, works better with higher compression and works best in the 1900-6000 rpm range. That tells me it isn't going to be good at torque down low and probably has a lot of overlap cutting cylinder pressure at lower rpm's. However I would think the compression jumped somewhat when you put the 95 kit in, if you used the original heads.
Old May 1, 2014 | 08:36 PM
pounder35's Avatar
pounder35
The Indy is saying to ditch the Thunderheader
Old May 1, 2014 | 08:41 PM
0ldhippie's Avatar
0ldhippie
543s actually should be pretty good down low. They have less overlap than 203s but too much lift for stock heads. My guess is the tune. But of course, thunderheaders suck.
Old May 1, 2014 | 08:52 PM
pounder35's Avatar
pounder35
Whats a better pipe.
Old May 1, 2014 | 09:23 PM
glide2005's Avatar
glide2005
Try SuperTrapp 2 to 1. I had 2 to 1 ThunderHeader on my 98" 2005. The TH was too loud, so I went with ST, A little quitter and a little bit more tq. I used all the disk and open end.
Lsc8
Engine Mechanical Topics
Aug 3, 2016 07:05 AM
CJL67
May 13, 2016 05:30 AM
ChangedBagger
13
Mar 15, 2015 08:01 PM
FXST
Aug 30, 2008 07:22 PM
dirtpan
Exhaust System Topics
13
Oct 27, 2007 06:12 PM
