Wiring Question
Old May 4, 2014 | 06:25 PM
DAWG_6's Avatar
DAWG_6
Default Wiring Question
Okay, so my cigarette lighter hasn't worked in quite awhile....replaced the lighter - that was not the problem.....then I installed the auxiliary charging unit in the tour pack....(plug and play with the existing wiring)....love it - works great...then I used the wiring that came with the kit that I didn't need due to the wiring in the ultra tour pack...to check the aux plug under my seat....tried the unit with that and the aux outlet under seat doesn't work....fuses all good (yes, I pushed the dash switch 'on').....I know I will need to test the wiring....will I have to pull all this through the wiring harness to find the short/problem?
Any similar experiences?
Thanks everyone.
Old May 4, 2014 | 06:28 PM
dawg's Avatar
dawg
How did you check the plug? Was the bike running?
Old May 4, 2014 | 07:36 PM
mkguitar's Avatar
mkguitar
you kinda lost me...
the ignition switch needs to be "on" or "acc"
check your fuses
check the lighter plug with the bike on---check that the plug hasn't fallen off the backside of the lighter socket.
for the aux plug under the seat there are 4 pins;
black is ground ( pin 4)
orn/red is hot when the bike is on ( pin 1)
red/yel is hot with the brake light ( pin 2)
orn is hot with your toggle switch ( pin 3)
mike
Old May 4, 2014 | 07:49 PM
DAWG_6's Avatar
DAWG_6
So does the bike need to be running for the lighter to work? or just in ignition mode or acc mode??
If it does I'm gonna laugh my butt off for being so stupid.
Old May 4, 2014 | 08:17 PM
RollaMo's Avatar
RollaMo
Ignition switch just needs to be in the "on" or "acc" mode.
Bike does not have to actually be running.
Socket is dead with ignition switch in the off position.
Old May 4, 2014 | 08:21 PM
DAWG_6's Avatar
DAWG_6
That's what I thought...so no cig lighter and no acc power.....gotta dig I guess.
Thanks.
lunatikfringe
Dec 7, 2014 09:16 PM
tooloudman
Aug 28, 2012 02:48 PM
SteveO
Mar 28, 2011 08:32 AM
scarab75
Feb 15, 2008 10:34 PM
Pastor John
Jan 29, 2008 05:24 PM
