if the fuse material is black and spattered, like burnt- that is a short circuit.
if the material has parted cleanly, just sagged and parted, then the circuit is overloaded.
i don't know what year you have.
on my 09, from the fuse, an or/grey wire carries power to the fuel pump, the power goes through connector #13A/B at pin 1, then to connector #141A/B pin 2 then to fuel pump. Nothing else is on the same fuse.
so maybe a chafed wire- which would be a short...or maybe a bad fuel pump motor.
you could try running a jumper wire bypassing the wiring harness, but risking a spark around fuel may not be so smart
for fuel pump health, fuel level should be kept high when possible- the fuel acts as a coolant for the pump motor.
