steering lock
Old May 13, 2014 | 06:37 AM
scrapper's Avatar
scrapper
Default steering lock
Well here we go spent almost three hours in a parking lot with a stuck steering lock, lucky someone gave a ride home and I got the tools to remove the lock assembly, and it looks like the spring is pretty rusted, question is can I fix this lock or should I just get a new one. My bike is a 2011Roadking.
Old May 13, 2014 | 09:49 AM
0ldhippie's Avatar
0ldhippie
Don't think it is serviceable? Ya may try soaking it in wd40 for a while and lubing it with triflow? But a new one is the best solution.
Old May 13, 2014 | 09:59 AM
larsfum's Avatar
larsfum
soak the snot out of it in oil. then give it a dose of powdered graphite.
Old May 13, 2014 | 10:00 AM
mkguitar's Avatar
mkguitar
alot of the road kings guys in my area have trouble with desert grit getting in the lock.
a cover can help with that.
I have had some luck cleaning gunk out of lock mechanisms using a "personal massager" to shake the grit loose.
and washing through a light lube- lighter fluid is pretty good for this. don't set yourself on fire. lighter fluid will wash through parts and then vaporate
follow up with graphite powder
( massager also works pretty good on the pipes under the sink the day after Thanksgiving.)
mike
Old May 13, 2014 | 10:12 AM
scrapper's Avatar
scrapper
Default lock
after further investigating the pin broke on the plunger I don't if that it the right part name that's why it wouldn't unlock , when I pulled the lock the pin and spring were laying there.
Old May 13, 2014 | 10:19 AM
UppercaseJC's Avatar
UppercaseJC
No on the graphite as my experience in when mixed together you gut mud. Just the oil will work.
steelerdude1
2014-2024 Touring Models
13
Jan 12, 2016 05:28 AM
hal174
Mar 14, 2014 12:15 PM
br549A1
EVO
Mar 5, 2014 06:57 PM
JC in Colorado
May 28, 2010 04:22 PM
alazlo
Shovelhead
Apr 19, 2006 11:15 AM
