Wards Fans
Old May 15, 2014 | 09:37 PM
Noble Jim's Avatar
Noble Jim
Default Wards Fans
I installed my Wards fans and have been watching my oil temp. It has not gone over 235 degrees, I am impressed.
Old May 15, 2014 | 09:53 PM
hog95023's Avatar
hog95023
Nice, I have a set waiting to go on.
Old May 15, 2014 | 10:02 PM
hattitude's Avatar
hattitude
I got'em on my bagger and will probably get a set for my softail too, even though that never gets as hot as the bagger....
I think they are the best looking fans and they work....!!
Old May 15, 2014 | 10:20 PM
Mac daddy 103's Avatar
Mac daddy 103
Nice!!! I have a deposit on a set
Old May 15, 2014 | 10:37 PM
hog95023's Avatar
hog95023
did you use the thermal switch?
Old May 15, 2014 | 11:20 PM
SR90's Avatar
SR90
My bike is a little noisy with V&H dresser duals, twin slash mufflers, and Woods 222 cams, I'm tempted to install these fans. Will I hear them? Also, will I feel the hot air blowing out the right side of the bike?
Old May 15, 2014 | 11:39 PM
Arizona's Avatar
Arizona
I've had my Wards fans for coming on two years now. They're the single best and most important thing you can do to keep the motor cool. Next is an oil cooler, then a Stage I.
My bike (set-up is listed below) runs 25-30* cooler with the oil cooler and Wards fans combined. The single biggest contributor to that is the Wards fans (probably 20*) and the oil cooler pushes it up to as much as 30* cooler on a hot day. In super brutal conditions like crawling in stop n go in 100*+ temps it's probably 40* cooler than it would be without those two things.
Excessive heat is a total non-issue now. I don't even think about heat anymore at all under any circumstances.
Old May 15, 2014 | 11:52 PM
RushKing14's Avatar
RushKing14
Since the Wards fans are designed around pushing are through the port holes/channels in the heads, I wonder how effective they would be for those that have added the head bolt chrome covers that fill that gap where the spark plugs go. It seems with that add-on, the fans wouldn't be able to get air into the port as it is blocked other than the hole for the plugs.
Anyone have these installed with that area filled and can comment on this?
Thanks
Old May 16, 2014 | 01:30 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Thanks
Spot on observation, and I always recommend against the head bridge covers, however some customers have left them on and have reported they are still happy with the results. I only recently established a valid dynamic testing method to show performance with and without fans. With my recent back injury, and some new competing demands on my time, I cant conduct a test anytime soon with and without the bridge covers. My assumption is cooling performance will be negatively affected however until its specifically tested, its just an assumption.
Old May 16, 2014 | 04:27 AM
Keithhu's Avatar
Keithhu
Very interesting. I never thought about this, but what you are saying is, if you forget about the fans for a minute, those bridge covers retain a not insignificant amount of heat.
I like my bridge covers, but now you have me thinking about taking them off!
