Hi all!
The holidays was very funny and loud )) It seems like a godzilla come to my speakers and ****** a piece of it. I need new speakers, but can`t find in stock HD 77029-01 (8 Ohm). I find this model in ebay, it has 65-22 kHz and 50 watt nominal.
At the same time i can replace rear speakers to front before i buy a new one, but...
Is there any variants to install something other vendors with 8 Ohm and other stock parametres? All speakers in our markets often has 4 Ohm.
ps I can`t find any piece of speakers inside the fairing. It happens when i use bluetooth through AUX out, i think (on max volume). Jabra has digital amplifier and it seems like a big distortion on Rammstein. Overdid)))
Thanks for advance!
Full range 8 ohm speakers are about impossible to find anymore. Ya could add an amp (rockford fosgate pbr3002) or swap out to a modern head unit so ya can run 2-4 ohm speakers. Lots of good info in the audio section.
3. http://www.harley-davidson.com/store...08-76000256--1
8 Ohm - original - Audio High Performance Boom! Bagger Electra Glide Fairing Speakers-76000256.
But, not sure about price. It`s cheaper to buy on Ebay, i think.
they are 2 ohm resistance on hd bike now-- i do have a set of 4 ohm on mine-- the higher ohm number i believe causes a bit more draw on radio and a bit higher volume setting for a higher sound level but work ok.
Hi there
All of our amplified systems will work on 98-13 bikes with no issue. As long
as you use our amplifier, the 2 ohm speakers are OK
Hope this helps--PEZ
