Run, Brake, Turn Signal Module
Old Mar 30, 2007 | 07:14 PM
bob53's Avatar
bob53
Default Run, Brake, Turn Signal Module
Just installed the HD run, turn signal module. It works great except the turn/brake lights are'nt very bright when you apply the brakes. Does anyone have this problem?? Do I need to install a dual filament bulb like the one in the brake light?? Any ideas on fixing the problem??
Old Mar 30, 2007 | 07:17 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: Run, Brake, Turn Signal Module
I Used Kuryakyn and also went to the LED's on the brake & directionals... Work GREAT!
Old Mar 30, 2007 | 07:19 PM
gman's Avatar
gman
first of all, you can't replace the bulb with a dual filament. they have two contacts, where as the turn signal only has one. i replaced my lenses with clear lenses, and on the rear put in red bulbs. i think they work great and are bright enough. course, you can never have too much light back there with all them cagers running around.
[IMG]local://upfiles/12616/CBF77A88E3FC4FE59FEBD20DD232D4E6.jpg[/IMG]
[IMG]local://upfiles/12616/C16F9C1DC5304B6796FAA6BC9EAAD1BE.jpg[/IMG]
Old Mar 30, 2007 | 07:23 PM
Dave_E's Avatar
Dave_E
Bob, the kit is OK. Wait untill your in the dark of night, they're fine. For the price of the kit, we got more light on our ***, that's one of the real purposes. My .02 Dave
Old Mar 30, 2007 | 11:50 PM
iclick's Avatar
iclick
ORIGINAL: SoCal_Pappy
I also have the Kury module, but haven't found a high-output replacement bulb for the center brake light. It is a funky blade-type mount that I haven't seen before, so the usual 1157-variety upgrades won't fit it. Exactly what are you using?
I'm told my two turn-signal bulbs with red lenses are very bright, even though they're the stock 1156-variety bulb, but the center light needs more oomph. If it was a stardard bayonet-mount like the 1157 I could replace it with a quartz bulb.
Old Apr 3, 2007 | 01:08 PM
pcsgrp's Avatar
pcsgrp
Before I replaced the back light with a panel led, I had a 3357 bulb. The running light is the same but the brake light component is about twice as bright.
Old Jan 17, 2008 | 04:24 PM
rome304's Avatar
rome304
went with the kury. smoked lenses red bulbs came out perfect also love the 3-flash before constant bright.
Bandito
Electrical/Lighting/Alarm
May 18, 2018 06:23 PM
jjaacooper
Mar 22, 2012 09:57 PM
twofish
Mar 13, 2012 10:54 AM
VinnySem
Oct 8, 2010 10:40 AM
khnt
Jun 15, 2008 04:48 PM
