AMSOIL (BEWARE)
Old Apr 1, 2007 | 08:54 AM
  #31
BUIZILLA's Avatar
BUIZILLA
Default RE: AMSOIL (BEWARE)
ORIGINAL: ricaroo
Last night I put a quart of amsoiloutside in the cold and when I got up this morning it was vibrating
I just spit out my coffee..... good one, brilliant reply... LOLOL
JH
Old Apr 1, 2007 | 09:10 AM
  #32
Bigredone's Avatar
Bigredone
I have anBeta bottle of newly developed Balanced Oil. Slicker than Sh@t. Any investors out there?
Old Apr 1, 2007 | 09:16 AM
  #33
RanD's Avatar
RanD
Its extremely silly to even suggest that the Amsoil caused the vibration. Tens of thousands (perhaps more) of bikes have Amsoil in their cranks without incident. Besides...you said that the vibration went away after things warmed up. I just don't think that you gave the Amsoil a fair try. I would ride with your HD oil for a thousand miles or so and then try the Amsoil again and see what happens. BTW, I don't currently use Amsoil, but I sure wouldn't be afraid to.
Randy
Old Apr 1, 2007 | 09:34 AM
  #34
Ram's Avatar
Ram
Check spark plugs! You may have to change your carbon deposts. They have to be rotated from time to time too!
Old Apr 1, 2007 | 10:13 AM
  #35
dan boudreau's Avatar
dan boudreau
WOW !. I am not saying that Amsoil is bad in any way.Heres the scoop same temp outside same fuel in tank, new spark plugs, parked in heated garage all winter on stands tires off the ground. I can not explain it or do I beleive that Amsoil would cause vibrations I do think that an engine, trans or primary can get used to a type of oil and have put 37,000 KMS (about 25,000 miles) with SYN3 and maybe that has something to do with it.I would bet that maybe if I put Amsoil back in the vibrations would be gone but now that I have put SYN3 back in both bikes at a cost of about $200.00 that its there to stay.
Old Apr 1, 2007 | 10:26 AM
  #36
red1beard's Avatar
red1beard
Hmm, lets think about this one. It's April one. Could this be your basic April Fools day post?
Old Apr 1, 2007 | 10:48 AM
  #37
dougbk's Avatar
dougbk
I hear that new slicker than **** balanced oil would cause your bearings to spin, ;-{)
Old Apr 1, 2007 | 10:49 AM
  #38
AtkRWC's Avatar
AtkRWC
ORIGINAL: dan boudreau
Well then why did you title the thread "AMSOIL (BEWARE)? I think this sounds like to most as a shot at Amsoil which has a loyal following here.
During warm up did you notice any of these vibrations? If you did notice vibrations during warmup why did you ride before investigating? If there were no vibrations during warmup and it started during your ride, at what speed did it occur? I would think that it would have been noticed during a takeoff/acceleration right off the bat and you would have stopped.
Having experienced engine caused vibrations and rotating mass/tire type vibrations, I can tell you that they are completely different and cannot be confussed with one another. Can you describe the vibrations in more detail? Did you feel it in the pedals or handlebars, ect..? This will help..
Old Apr 1, 2007 | 12:01 PM
  #39
VROCK SE's Avatar
VROCK SE
It is the Blinker fluid that is un balanced!!!
Old Apr 1, 2007 | 12:12 PM
  #40
relli's Avatar
relli
my vote is for amsoil first m1 second
