AMSOIL (BEWARE)
Old Apr 1, 2007 | 08:40 PM
  #51
ricaroo's Avatar
ricaroo
Default RE: AMSOIL (BEWARE)
UPDATE:
I put the Amsoil in the sun and as it warmed the vibrating stoped, I quickly emptied the container and added SYN 3. I plan on putting the container out in the cold againtonight and see if I was able to dilute the Amsoil enough that the vibration is eliminated. This hopefully will work as the container is a favorite of mine.
ORIGINAL: ricaroo
Last night I put a quart of amsoiloutside in the cold and when I got up this morning it was vibrating
Old Apr 1, 2007 | 09:05 PM
  #52
cjmorrell's Avatar
cjmorrell
2nd Gear
I am purchasing a 2007 Springer with all maintenance included at no charge, called the Family Plan at Rice Lake HD, Wisconsin. I am also an AMSOIL dealer and will go with the no charge maintenance (fluids included), saves tons of dough! Even thought the AMSOIL products are the top of the line!
Old Apr 1, 2007 | 10:09 PM
  #53
deer30084's Avatar
deer30084
Well I'm usn' Castrol 20W50.
Old Apr 1, 2007 | 11:32 PM
  #54
Dogwood's Avatar
Dogwood
I like Vodka and Amsoil on the rocks with a twist of lime.
Goes down smooth.[8D]
Old Apr 1, 2007 | 11:35 PM
  #55
apachethunder03's Avatar
apachethunder03
syn3 in all 3. I don't remember where but I read that you can go 10k with out changing the fluid in the primary and trans if you use syn3.
Old Apr 2, 2007 | 02:14 AM
  #56
texas tom's Avatar
texas tom
I believe harley came out with a buletin uping tranny and primary to 10k some time last year,I can see that in the tranny most of the time I change it still looks brand new,but the primary? That oil looks like crud every time it is changed think ill still change it every 5k..Tom
Old Apr 2, 2007 | 10:37 AM
  #57
Chicago Spike's Avatar
Chicago Spike
The color of oil has very little to do with it's protection. OIl changes from that gold color to a dark brown very fast from heat, and is normal. Not saying that you changing your oil more often is bad, just saying don't judge the oil by its color
Old Apr 2, 2007 | 12:52 PM
  #58
DAWG_6's Avatar
DAWG_6
ORIGINAL: ricaroo
[sm=funnypostabove.gif]
Old Apr 2, 2007 | 01:07 PM
  #59
glide's Avatar
glide
Amsoil is the origional cause of bearing skate and causes flat spots on roller bearings
Old Apr 2, 2007 | 04:13 PM
  #60
larry5h's Avatar
larry5h
tires
