high output charging system (2011 CVO 110)
Old Jun 15, 2014 | 09:09 AM
flhtcuse6's Avatar
flhtcuse6
Stage IV
Default how reduce current draw ??
I thought of another question... are there any easy ways to reduce the current draw ????. it's easy to not turn on some options (heated seats, radio, extra headlamps, etc). Wondering if the LED headlamp would help. ?? maybe any other ideas.
..... Mike
Old Jun 15, 2014 | 09:11 AM
UltraNutZ's Avatar
UltraNutZ
headlamps (aside from the actual starting of the bike) draw more current than anything stock on your bike so yes LED headlamps reduce that significantly, by at least 50%
Old Jun 16, 2014 | 07:51 PM
flhtcuse6's Avatar
flhtcuse6
Stage IV
Default LED headlamps to reduce current draw
I found the LED lamps from Truck-Lite, below
It looks like this kit would reduce my amperage much.
(if using low beam and passing, from 8.9amps to 2.9amps
wow, i'll macke sure these fit my bike, and this will help alot)
Low beam current draw 1.5 amps (stock halogen is 4.9 amps)
High beam current draw 2.3 amps (stock halogen is 5.5 amps)
Passing lamps (pr) current draw 1.4 amps (stock halogen (pr) 4.0 amps
http://www.discountfleetsupply.com/tlc27270c-3set.html
Qty (1) Truck-Lite 27270C
Qty (2) Truck-Lite 80275
heck, this is a 6amp reduction and better lighting for ~$350
I hope i'm looking at this correctly
Sagido
2014-2024 Touring Models
Sep 15, 2017 08:11 PM
ScottinAZ
Electrical/Lighting/Alarm
Sep 9, 2017 08:51 AM
halmc
Jun 13, 2017 05:28 AM
iwillfixthem4u
Mar 2, 2016 10:01 AM
chedderbandit
Audio Systems
Feb 23, 2014 02:59 PM
