Quiet Slip-Ons?
After doing a bit of reading and hearing others experience and suggestions, it occurred to me that as previously suggested - one of the supertrapp based systems may be best and "should" save buying one slip-on after another in search of the right one. Disc systems have never been my favorite on the looks side of things but performance and sound have to come first I suppose.
One of the main reasons I chose the street cannon was in the belief that a 50 state epa approved pipe would be pretty quiet - which is correct until you pull the cat from your header, then you have a mild to middle of the pack on the obnoxious scale. I'll probably also give Samson a call to see what they have to say but that seems like the most expensive option.
Could someone point of the main difference between the SE Fatshotz and the Nightstick? There's around a $70 difference and other than appearance they seem mostly the same thing other than the Fatshotz have the open end cap and that seems odd for an epa approved system.
both versions should be marked as epa compliant for 96/103/110.
I know that the first version of the fatshots was not marked for the 110...so there is a A suffix added when the stamping was changed
the open end cap is compliant as the fatshots was introduced for 2010...same time as the cat.
that indicates how much an effect the cat has on sound- those pipes as stock are pretty darn loud on a catless header
the fatshot has a 2" perforated core- hold it up to light and you see all the way through it.
the baffle has a packing on the outside which is repackable and will require probably every 20 or 30K miles. this perf/packing helps to soak up high frequency noise
it comes with 10 disks and a 1.4" open end cap- the 1.4" hole is equivalent to 9 disks stacked in terms of flow.
so a flow "factor" of 19.
the core is capable of flowing to a "factor" of 27 according the supertrapp.
the nightstick is solid core- no perforations. because of this tinnier sounding if used with open end cap, which is why I think the solid end cap came on that.
both of these made by supertrapp for S/E, all the 4" disks and end caps on ebay will fit.
On my 09 I use modified fatshots, I have selected the number of disks that works for what I do ( 8 left, 15 right) and usually a solid end cap
(all this assumes you can get your hands on a Security bit")
I've has a S/T supermeg on my FXR since 1990. as the motor has been built, the pipe is retuned to match.
I have also used supermegs slip ons on baggers with stock no cat headers.
the S/E versions are functionally the same ( AFAIK) and usually a lot less expensive- the S/T bagger slip ons were a Ness exclusive for years and pricey...
mike
the nightstick is solid core- no perforations. because of this tinnier sounding- which is why I think the solid end cap came on that.
mike
because we get more flow from the right side...I have an uneven disk count L/R
to make it look right, I have a solid cap in the middle of the left side disk stack...you'll see the line in the pic below ( these are my supertrapps)
and I use solid end caps...most of the time. the caps in the pic are 1 version of what is available, there are also thin stainless caps which is what i use in that above left stack.
or put a black painted solid cap inboard of the open end cap- these are fatshots...and there is a solid cap in there:
( the black trim ring can also be polished which looks nice)
or get some snuf r nots, which allow open/close with an allen wrench...that's what I have on right now as I was doing some group rides and wanted to be heard a little better by other riders
mike
Mine were plenty loud after the de-cat and now have went with the 2/1/2 head pipe and the sound went up a little more. Just for the heck of it I installed my freshly re-packed Rush 1 3/4" and the sound was too much and the butt dyno said no gain in performance. IMO the stock mufflers are great and after a 300 mile day that sound is about all I want to hear. Another good thing about running stock mufflers is the sound cops cant say or do a thing.
NBC - YouTube
