Looking at Picking up A 96 King , questions
16k is nothing...I gotta couple of evos over 80k
at that age is may need some rubber stuff and bushings replaced, but no real concerns.
mike
16k is nothing on an Evo,but the age of the tires comes into question.
The only thing I would suggest is replacing the intake seals.
- Seats-If you plan on swapping out the seats beware that 97' on up seats will not fit this bike. Apparently they have the old style mount
- Does it have fuel injection or carburetor? If it has FI beware the 96' ECM is not programmable and that along with the MM Fuel Injection doesn't play well with mods. If you plan on going to a stage one or higher, you will need to swap out the ECM to a 97' or newer. Apparently H-D figured this out in '97
- The EVO motor from 84'-98' is bomb proof. Great motor. A bike that old may have some weeping at the base gaskets due to the paper gaskets used from the factory. No big deal if it weep a little oil but may be an issue with a bike that old with so few miles.
- 16K is nothing for a 18 year bike. That's 889 miles per year!
FI/Carb - I had the FI version. Keep in mind not only is it not programmable, the parts are EXTREMELY hard to find. For the first 10 years or so I had it it was relatively reliable.. but when it started to die, it was a major pain in the ***. I eventually had it converted to CARB but keep in mind the FI version of this bike uses a COMPLETELY different wiring harness than the non-FI versions.. which means to swap out you need to find a very rare wiring harness or have someone who can completely rewire it.. My guy ended up going with a 1998 harness and had to extend a bunch of the wiring.
Also, the ECM is MASSIVE and also very hard to find replacements for. I kept my ECM originally after we converted to carb to control the electronics but eventually it died. A replacement was in the $1000 range.. at that point I had to do the re-wire and eliminate the ECM.. the problem there was again that the FI version uses different components electronically, different connectors, and was damn near impossible to find replacements for. The Fuel tank is also different for FI and had to be modified for Carb use..
Moral of the story.. if its FI, I would not purchase it. Not because its a MM FI, but because its a very rare 1 off year version of the MM FI. Its my understanding they trashed it after 1996 (Only used it for 1 year) and went to the newer MM FI's in 1998.
If its Carb.. ignore all of that and I would not be concerned about the miles. The EVO is relatively cheap to repair and parts are easily available.
