Strange problem
Old Jun 24, 2014 | 07:50 PM
  #31
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
This just in:
It was a wire to the IMAP sensor that was broken inside the silicon insulator. The wires were a little tight in the loom going to the sensor. When the back brake was applied the engine leaned forward, breaking the circuit...... I'm back on the road burning refined dead dinosaurs.
Old Jun 24, 2014 | 07:56 PM
  #32
Boomer1143's Avatar
Boomer1143
Originally Posted by shooter5074
This just in:
Glad you got it straightened out.
Old Jun 24, 2014 | 07:57 PM
  #33
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Too Cool. What is the difference between a MAP and a IMAP or are they totally different sensors?
Old Jun 24, 2014 | 08:11 PM
  #34
mkguitar's Avatar
mkguitar
I think Shooter means "TMAP" Temperature Manifold Absolute Pressure which measures the density of the air in the intake which will vary with altitude, temperature and local weather variations.
Shooter, I have questions:
Were there stored codes which indicated a problem with the sensor?
Was the wiring harness stock and unmodified?
Mike
Old Jun 24, 2014 | 08:17 PM
  #35
Jackie Paper
Mike
You're probably correct. I was scratching my head on that one. Older bikes like mine have a MAP (manifold absolute pressure) and a separate ET (temperature sensor).
Old Jun 24, 2014 | 08:37 PM
  #36
titched's Avatar
titched
Good for you. Just curious how did they diagnose the problem? Enjoy your trip now?
Old Jun 24, 2014 | 08:58 PM
  #37
shooter5074
Mike
Yeah, sorry, can't read my own writing it is TMAP.
There were tons of codes. But none pointed to the TMAP. Loss of serial data to ECM. Loss of data from ABS. Multiple cruise control drop out, etc, etc. But nothing pointing to the TMAP.
Wiring was stock. The factory just had a wire tie a little far back and caused the wires to go tight when the engine was rocked forward on the mounts.
Strange that it took 40K for it to show up.
They found it by testing wires one at a time, and just got lucky, and found it within the first hour. Once they found it, they could kill the engine by pulling on the wire to break the connection.
The tech cut the tie, and made a nice slack loop, and replaced the connector.
Old Jun 24, 2014 | 11:00 PM
  #38
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Glad it was a simple fix man. Back on the road again!
woohoo!
Old Jun 25, 2014 | 07:50 AM
  #39
Jackie Paper
This was a cool post. 1 in a 1000... A complicated problem. A fix. And a blow by blow of the fix. Probably 1 in 10,000 on here. Thanks Shooter.
Old Jun 25, 2014 | 10:10 AM
  #40
TheGrandPoohBah's Avatar
TheGrandPoohBah
Is there excessive engine movement at the mounts?
Look normal?
